Dell Inspiron 15 5559 AAL15 LA-D071P battery not charging
  • shatteredhalo
    • Dec 2019
    • 6
    I'm troubleshooting an issue with a laptop where it doesn't seem to want to charge the battery. The laptop will run off the battery alone and use/drain the battery normally in this situation, it will run off the AC adapter alone, and it will run with both charger and battery connected, but it doesn't seem to charge the battery under any circumstance.
    At startup of the laptop, the following error message is displayed by Dell SupportAssist: "Alert! The AC power adapter wattage and type cannot be determined. The battery may not charge. The system will adjust the performance to match the power available." I disabled this alert in the BIOS. I know the adapter is of sufficient wattage and voltage as it matches that of the original factory charger which has since been lost (45W, 19.5V), so I think the laptop is just mad it's not official Dell. However, it should still be working.
    In Windows 10, the battery icon in the lower right tray will say "plugged in" when hovered over, but never anything about charging. I used a free battery monitoring program (BatteryCare) to confirm that no charging of the battery is occurring. Periodically Dell Power Manager Lite will display a popup in windows similar to the startup warning about the adapter not being recognized, blah blah.
    Info / Things I have tried:
    1. I am on the latest applicable BIOS from Dell's site.
    2. Many common "fixes" for non-charging batteries found on the internet such as: plugging in the laptop, turning it on, removing the battery, uninstalling the battery drivers from device manager, shutting down the laptop, leaving the battery out for several hours, reinserting the battery and turning the laptop back on.
    3. Swapped out the DC charging port on laptop.
    4. Tried a brand new battery.
    5. Tried a brand new 65W charger (universal).
    6. I even reset the Windows 10 installation... just in case...
    It seems like from 3, 4 and 5 seem to rule out the battery, charging cable, or dc port being the issue...
    Then I found these schematics:
    https://www.badcaps.net/forum/attach...5&d=1517020862
    (original post: https://www.badcaps.net/forum/showpo...7&postcount=13 )
    And took some measurements of PJPDC1 and PBATT1:
    PDPDC1 pins:
    1. 0V
    2. 0V
    3. 3.39V
    4. 0V
    5. 19.5V
    6. 19.5V
    PBATT1 pins (no battery, charging cable only):
    1. 0V
    2. 0V
    3. 0V
    4. 3.32V
    5. 3.34V
    6. 3.34V
    7. 0.05V
    8. 0.05V
    PBATT1 pins (battery inserted + charging cable):
    1. 0V
    2. 0V
    3. 0V
    4. 0V
    5. 3.23V to 3.28V
    6. 3.22V to 3.28V
    7. 15.17V
    8. 15.17V
    I am admittedly not very familiar with reading electronic schematics, but am I understanding correctly that PBATT1 pins 7 and 8 SHOULD be 17.4V? Are my measurements indicating that the battery is not receiving sufficient voltage to charge, and thus not charging at all?
    Sadly I'm at a bit of a loss for where to go from here... it seems like the problem should not be the battery, charger, or DC port. It seems the only culprit left would be the motherboard (or something on it), but the idea of spending $150+ on a new board and trashing this whole old board when the possible fix might be replacing a single chip for a few bucks is frustrating.
    Thanks for reading and I appreciate any help/ideas/input!
    • 20967
    Re: Dell Inspiron 15 5559 AAL15 LA-D071P battery not charging
    "I know the adapter is of sufficient wattage and voltage as it matches that of the original factory charger which has since been lost (45W, 19.5V), so I think the laptop is just mad it's not official Dell. However, it should still be working."
    Use a genuine charger,9 times out of 10 the problem is solved.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Check pin 36 of kbc MEC-1404 for 3.3V. This is your ps id signal. Dell are known to have failure in ps-id circuit. But first check the voltage on that pin and report back.
      • shatteredhalo
        • Dec 2019
        • 6
        It was really difficult to be sure I was touching just pin 36 because I think I just need a smaller probe and a more powerful magnifying glass, but it seems to be about 3.39V.
        • shatteredhalo
          • Dec 2019
          • 6
          I've ordered a Genuine OEM Dell charger to try. Unhelpfully, the bottom of the laptop under the battery shows 19.5V and 2.13A/3.34A... so it's not really clear if it needs 45W or 65W. I got a 65W one to be safe. I'll update when it arrives on Tuesday.
          • shatteredhalo
            • Dec 2019
            • 6
            The genuine Dell charging cable came in today and... It seems to be working. Does this mean Dell actively prevents third-party chargers from working? Is that even legal? Especially when so many universal chargers also claim to work on Dells?
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3597
              • slovakia
              thats for "middle pin" is made
              dell wont charge for many years. now there are many vendors that is using middle pin/hp lenovo .../
              • SERVILAP
                • Aug 2014
                • 3
                • mexico
                Hello, in my case it does not detect an ac adapter, but if I have 3.3v on pin 36 of the KBC, I connect the battery and it flashes white and orange, it does not send power to the battery
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Is the adapter recognised in bios setup only on ac adapter(battery removed)?? If no, you have problem in psid circuit. Schematic available, so check it.
                  • SERVILAP
                    • Aug 2014
                    • 3
                    • mexico
                    the adapter is not recognized by the bios, but if I have voltage in psid
                    • Sametbey
                      • Jan 2021
                      • 229
                      • Turkey
                      notebook adapter and DC_IN input circuit must be compatible.
                      I'm not happy to be so strong. because it's not humanly
                      • rookieme
                        • Oct 2014
                        • 397
                        • Greece
                        if you still have this issue do reply - I know the solution!
                        • giagi
                          Giagi
                          • Oct 2017
                          • 10
                          • canada
                          rookieme
                          i have an inspiron 15 5555
                          with this problem
                          can you help
                          thx
                          giagi
                          • mon2
                            • Dec 2019
                            • 14239
                            @giagi - does your logic board look like the attached ?
                            • dudochnicht
                              • Nov 2020
                              • 25
                              • GER
                              Originally posted by giagi
                              rookieme
                              with this problem
                              can you help
                              thx
                              giagi
                              hello giagi, some time ago i repaired 2 dell inspiron 5559/5558 and both had a defective power supply. The laptop turned on anyway, the same message came up and it was really slow in Windows and the battery was not charged. Just change the power supply and it should work again.
                              Only use original Dell 65W power supply!
                              • giagi
                                Giagi
                                • Oct 2017
                                • 10
                                • canada
                                Thanks for responding. I need to dissassemble it. I really need a schematic of the circuit
                                from input power adapter to the battery. There is a an IC MUX switch that could be causing this trouble.
                                • mon2
                                  • Dec 2019
                                  • 14239
                                  After you open the box - confirm if the logic board looks like what I posted earlier.
                                  • giagi
                                    Giagi
                                    • Oct 2017
                                    • 10
                                    • canada
                                    ok will do
                                    • giagi
                                      Giagi
                                      • Oct 2017
                                      • 10
                                      • canada
                                      yes the board looks like the one you posted
                                      except the numbers on mine are
                                      AAL12 LA-C142P
                                      rev3 (A02)
                                      2015--05-19
                                      • Bowline
                                        by Bowline
                                        06-11-2025, 10:13 AM
                                      • Julian Bailey
                                        HP ProBook 445 G8 Battery not charging
                                        by Julian Bailey
                                        Hi all
                                        We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                                        The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                                        I have gone around the board with a MM and cant find anything
                                        Windows shows the battery fine,...
                                        10-11-2024, 10:34 AM
                                      • piernov
                                        Laptop battery charging circuit
                                        by piernov
                                        1. Some theory
                                        1.1. Introduction
                                        Almost every laptop has a charging circuit of some sort, that does a few things:
                                        • Manages switching between AC adapter and battery power
                                        • Manages battery charging and generates power rail to charge battery
                                        There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
                                        • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
                                        • Narrow VDC (NVDC)
                                        Texas instrument has a nice overview of these technologies with some more details at https:...
                                        11-15-2020, 01:31 PM
                                      • kodox
                                        ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
                                        by kodox
                                        since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
                                        the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
                                        what i've done:
                                        - flashing...
                                        12-29-2024, 02:49 AM
                                      • Shinju
                                        Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                                        by Shinju
                                        Hey All!
                                        Long time forum member here with a problematic laptop issue!
                                        I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                                        The laptop would not power on with the new battery installed without the power supply being plugged in.
                                        When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                                        TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                                        10-20-2021, 04:58 PM
