HP 250 G3 [LA-a992P] System Temperature (90D) error
  • classicandy
    • Apr 2018
    • 309
    • Nigeria
    Hi all
    I have this HP 250 G3 [LA-a992P] that sometimes shuts down and when I turn it on again, it shows this "System Temperature (90D), Thermal Shutdown has occurred" error.
    The system doesn't get hot abnormally, fan is working well. Fan speed increases after sometime and shuts down.
    I seem to suspect a faulty thermal resistor but not sure.
    Here is the schematic diagram
    https://www.badcaps.net/forum/attach...1&d=1464656128
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Re: HP 250 G3 [LA-a992P] System Temperature (90D) error
    if u dont have that error on cold start than u must have thermal problem.
    check heatpipe for leakage
    • classicandy
      • Apr 2018
      • 309
      • Nigeria
      heatpipe has NO leakage. Can't it be that the system is having incorrect readings from the therm sensor or so?
      I've checked the value on a thermistor near PUZ2 and its reading is similar to 2 other same type of motherboard.
      Also, sometimes, the mouse touchpad and the keyboard can just seize to respond, but external mouse would work at that point.
      • lapfix
        • Mar 2020
        • 2765
        • my workshop
        Maybe this can help you to understand more : https://www.youtube.com/watch?v=2gnUvdP7fTk
        • classicandy
          • Apr 2018
          • 309
          • Nigeria
          Thanks for this.........
          Audio in Hindi, hard to understand but would try to study it somehow.....
          • lapfix
            • Mar 2020
            • 2765
            • my workshop
            I know for the hindi language , me too i can't understand but his diagnostic is interesting and informative
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              R62 has thermal i/o protection whereas A992 doesnt have it. So the two scenario's are different. Check PROCHOT# signal.
              • Sus256
                HISENSE 65E7KQ PRO - no boot
                by Sus256
                Hi all!
                HISENSE 65E7KQ PRO
                RSAG7.820.13512 - chassis
                MT9618BAATAB - cpu
                RSAG7.820.12059 - power
                HD650Y3U77 - panel
                KLM8G1GETF - emmc
                The TV does not turn on, the standby indicator is on. All voltages are present.
                Emms is dead. Not readable, not detected.
                Replaced emmc.
                But with another dump there is no launch
                Terminal log
                UART
                AC_ON
                RPMB key is not yet programmed
                HASH1_VERSION=0x00000000 64bit
                E-B
                FDE enabled
                layout pattern onebin by SAR7,0...
                06-01-2025, 02:11 AM
              • sushilachuthan
                APC UPS error P13
                by sushilachuthan
                one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
                the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
                The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
                We replaced the SCR with new device,, but the device is not power on as expected.
                Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
                09-26-2025, 09:00 AM
              • Superbee_dad
                Sharp 80” long short flash backlight error - Help
                by Superbee_dad
                Hello Sharp TV experts
                Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                01-24-2025, 11:51 PM
              • amigo744
                PS5 CFI-1016A DISK shuts down only when playing ps4 games error ce-108262-9
                by amigo744
                Hello there,
                ps5 cfi-1016a disk console
                Problem: ps5 shuts down when playing ps4 games after cold boot with error code ce-108262-9.
                After the shut down the console boots up normal and then the ps4 game functions without a problem.
                ps5 games run allways without any problems after cold boot.
                Thats absolutely curious....
                I have already rebuild database, clean cache and reinstall latest firmware with usb stick in safe mode.
                That doesen´t help
                Furthermore i have opened console and renew liquid metal on gpu.
                This all doesn´t...
                06-19-2023, 05:02 AM
              • Curtissimo
                HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                by Curtissimo
                Hi everyone.
                I have a HP Elitebook 850 G8.
                Serial: 5CG2324XM0
                ProdID 6L8D5EC#ABA
                It has a Winbond W25Q256JVEN Chip.
                I need to remove BIOS Password.
                I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                Attached my dump.
                I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                What I did:...
                08-26-2025, 04:42 AM
