Repeated short circuit. P channel mosfet keeps blowing up
  • IamPritesh
    • Aug 2017
    • 356
    • India
    Hello friends, hope everyone is safe and healthy in this pandemic.
    So I have this Dell 3521 ( LA-9104P ) which has this strange issue of short circuit coming even after replacing the failed component,
    THe short always happens on the 1.5V line and everytime it shorts a different component on the same line including the second mosfet.
    So I first replaced the IC on PU300 (RT8207)
    First it instance ( PQ101, PQ300, CD39)
    Replaced both mosfet and removed the capacitor..
    Second instance ( PQ101, PQ300, CD14)
    Third instance ( PQ101, PQ300, PC308)
    And now we have this ( PQ101, PQ300, QC3) as shorted.
    Please advise how to find the real cuplrit.
    Schematic attached for reference .Thanks
  • peste
    • 13630
    • ROMANIA
    Re: Repeated short circuit. P channel mosfet keeps blowing up
    measure the 1.5v rail and see if it is short, with the L300 removed ... inject 1.5v, 3-5A in point 1 and see if something heats up ...
    • IamPritesh
      • Aug 2017
      • 356
      • India
      I inject voltage and found one component heated up like the examples given above. I remove it then shorting is removed and next when I PLUGIN THE ADAPTER again some new component gets shorted .
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        did you replaced PU300 with exact match?? Only matching RT8207 wont do, suffix also needs to be matched. Btw RT8207MZQW=Richtek code J7
        • IamPritesh
          • Aug 2017
          • 356
          • India
          Thanks for your reply.Hope you are doing well sir.
          Replaced from the same donor board and they are identical. I have never encountered this before thus pretty much annoyed at myself . The moment I remove /replace shorted component, and plug the adapter, the fan spins for a second and then adapter light goes off.
          Something is triggering the short circuit over and over again.
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            encounter this problem with hp laptop it destroy all the mosfets that is inline with processor vcore the moment you power it on. shorted mosfets replaced with new it shorted out what i did is check very well all the buck capacitor. i replaced a 330uf that checked fine with testers even with esr meter but in circuit it trickle a short not dead short but just trickle short.. i pulled out all the capacitor and test it out using just voltage to load the cap then use a oscilloscope and you will see the cap shorting out randomly. try to place new capacitor and new coil specially the 1R0 or 36R, just try it..
            • IamPritesh
              • Aug 2017
              • 356
              • India
              Thanks for sharing your experience. . Buck capacitors.. you mean polarized capacitors ?
              • Shrimp_Green
                • Sep 2018
                • 8
                • Brasil
                Hello, greeting from Brazil.
                Short on high mosfet is dangerous, not good at all. If the 19v B + arrived at 1.5V it may have damaged components in that line. For example ram. Replace the ram.
                Always replace the pair of mosfets, in the case of PQ300 and PQ301.
                Attention to the 1.5V line, check if there is no short
                • Duranitron
                  • Jul 2014
                  • 544
                  • Philippines
                  yah.. 330uf , 220uf or 100uf polarized cap..
                  • Scotchmist
                    Asus GA502D keeps blowing mosfet
                    by Scotchmist
                    I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                    I have removed the mosfet and can run the laptop no problem
                    The MOSFET is FDPC5018SG
                    Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                    08-24-2024, 02:23 PM
                  • Jane
                    How do you test MOSFET in laptops ?
                    by Jane
                    I tried to use this method:
                    Testing an N-channel MOSFET:
                    Step 1: Discharge the Gate (turn off the MOSFET)
                    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                    Step 2: Charge the Gate (turn on the MOSFET)
                    Now, place the red probe on the Gate (G) and the black probe on the
                    09-27-2024, 03:31 AM
                  • Nooy
                    VGA MOSfet permanently shorted and loss of MOSfet pad
                    by Nooy
                    Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                    I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                    02-14-2024, 02:26 AM
                  • redbaron1007
                    Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                    by redbaron1007
                    I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                    Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                    09-09-2025, 11:10 AM
                  • AppleLover123
                    Asus X712EA 3 volts after the first mosfet
                    by AppleLover123
                    Hey guys,
                    i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                    I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                    Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                    I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                    Now i thought something...
                    12-15-2024, 07:49 AM
