HP Elitebook Caps Lock Blink one time
  • battery.12v
    • 123
    • NW
    HP elitebook 480 G3 Blink 1 time .... Cpu Failure ... changed CPU Controller still same problem, Vcore REsistance after raising pin coils is 5 Ohm,and Diode mode 0.003 constant result even when reversing probe prolarity on Vcore CPU ... and OL on Controller side
    is this a measurements of Dead CPU ?
  • pecrie
    • Nov 2011
    • 182
    Re: HP Elitebook Caps Lock Blink one time
    See my post of today - maybe it can help
    I don't have a Elitebook
    • RJARRRPCGP
      • Jul 2004
      • 6304
      I was unable to analyze components, but it could be the same issue as the 2009 Athlon II HP CQ61.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • Curtissimo
        HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
        by Curtissimo
        Hi everyone.
        I have a HP Elitebook 850 G8.
        Serial: 5CG2324XM0
        ProdID 6L8D5EC#ABA
        It has a Winbond W25Q256JVEN Chip.
        I need to remove BIOS Password.
        I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
        Attached my dump.
        I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
        I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
        What I did:...
        08-26-2025, 04:42 AM
      • Kiwi Viking
        HP Elitebook 855 G8 all of a sudden does not power on. 7 flashes of Caps lock and Number lock prod ID 4X5S2PA#ABG
        by Kiwi Viking
        HP Elitebook 855 G8
        Product ID:4X5S2PA#ABG
        Motherboard M53301-601.
        Hi Gurus, I am wondering if someone might be able to help. I purchased recently this used computer that otherwise looks in mint condition. I worked for 1 week, until one morning I shut down the computer using the power off commands in windows. There was no warranty. This was purchased for my teenager for use at school.
        When I went to start the computer up in the afternoon, all the keys lit, but the computer didn't POST. Then the next thing I tried (pressing the power button) resulted in only the...
        03-01-2025, 01:05 AM
      • esqmooo
        HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
        by esqmooo
        Hello everyone.
        This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
        Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
        Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
        I tried long pressing on the power button, after several seconds it would go off then when the button is released...
        03-11-2025, 03:57 PM
      • battery.12v
        LA-B972P Caps lock Blink one Time
        by battery.12v
        15-r259ne LA-B972P came no display, caps lock blink one time (CPU not Functional)
        CPUcore is present 1.73V, all other voltages are present also 5v,3.3., 1.35v, 1.05v , gpu volt
        any guidance ? flashed too many bios files but no luck
        08-13-2021, 12:08 PM
      • AdrenalinTL
        Caps and num lock blink 4 times
        by AdrenalinTL
        I am sitting with a very similar issue.
        Basically, had a probook that worked, gave it to someone, they returned it DOA. what the heck happened, I have no idea.
        Caps and num lock blink 4 times, as per HP, thats a board failure. I am very new to this, so perhaps I should be posting a new thread?
        Anyway, I resoldered the bios chip on after trying EVERYTHING else including reseating ram, cpu etc.
        Multimeter shows 19.5V on power, so I presume thats correct. Fan spins, no display. No post. Bios chip looks good from what I can tell just not sure how...
        04-09-2024, 10:34 AM
