LA-B972P Caps lock Blink one Time
  • battery.12v
    • Dec 2014
    • 123
    • NW
    15-r259ne LA-B972P came no display, caps lock blink one time (CPU not Functional)
    CPUcore is present 1.73V, all other voltages are present also 5v,3.3., 1.35v, 1.05v , gpu volt
    any guidance ? flashed too many bios files but no luck
  • Sephir0th
    • Oct 2020
    • 1262
    Re: LA-B972P Caps lock Blink one Time
    Using known working DDR3L RAM?
    Check VIDALERT_N, H_VR_READY, PCH_PLTRST#, PCH_PLTRST#_EC, DDR3_DRAMRST#_CPU
    You can find Schematics Here: https://www.badcaps.net/forum/showpo...75&postcount=2
    FairRepair on YouTube
    • battery.12v
      • Dec 2014
      • 123
      • NW
      It is not the same board, i cannot measure the signals
      • Sephir0th
        • Oct 2020
        • 1262
        And what Board is it then? Full Board Number including Revision.
        Also Pictures Would be nice
        • piernov
          • Jan 2016
          • 4435
          • France
          Board is LA-B972P as indicated in OP. Link points to LA-A972P schematics which is a completely different board, it has been moved to its own thread with corrected title.
          • Sephir0th
            • Oct 2020
            • 1262
            Thank you for clarifying. Missed that. And of course, my apologies
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              You can use LA-A992P schematic. Its 90% similar.
              • AdrenalinTL
                Caps and num lock blink 4 times
                by AdrenalinTL
                I am sitting with a very similar issue.
                Basically, had a probook that worked, gave it to someone, they returned it DOA. what the heck happened, I have no idea.
                Caps and num lock blink 4 times, as per HP, thats a board failure. I am very new to this, so perhaps I should be posting a new thread?
                Anyway, I resoldered the bios chip on after trying EVERYTHING else including reseating ram, cpu etc.
                Multimeter shows 19.5V on power, so I presume thats correct. Fan spins, no display. No post. Bios chip looks good from what I can tell just not sure how...
                04-09-2024, 10:34 AM
              • computeka
                HP 14 Caps lock blink 1 time
                by computeka
                DA0U93MB6D2 Rev.D
                hello people !, thanks for attending me, I have the problem with an HP 14 that turns on but does not give video and the caps lock blinks 1 only time every 3 seconds, any idea what it could be ?.
                09-10-2021, 01:21 PM
              • dclass-pro
                Hp DAOP5FMB6A0 blink caps/lock problem
                by dclass-pro
                Hi guys, I have an HP model 15s-eq1040nl main DAOP5FMB6A0 REV:A with a caps/lock 5 long 3 short led flashing problem, I tried to remove the battery and program a new bios and when I restarted it immediately worked correctly, the pc turned on and loaded the operating system.
                As soon as I turned off the pc and connected the battery, the problem reappeared... caps/lock 5 long 3 short led flashing again!
                the battery was dead, i charged it and it works fine, but the pc won't turn on again.
                What do you recommend me? Do I have to redo the bios or is there anything else to check?...
                05-08-2023, 12:46 PM
              • Kiwi Viking
                HP Elitebook 855 G8 all of a sudden does not power on. 7 flashes of Caps lock and Number lock prod ID 4X5S2PA#ABG
                by Kiwi Viking
                HP Elitebook 855 G8
                Product ID:4X5S2PA#ABG
                Motherboard M53301-601.
                Hi Gurus, I am wondering if someone might be able to help. I purchased recently this used computer that otherwise looks in mint condition. I worked for 1 week, until one morning I shut down the computer using the power off commands in windows. There was no warranty. This was purchased for my teenager for use at school.
                When I went to start the computer up in the afternoon, all the keys lit, but the computer didn't POST. Then the next thing I tried (pressing the power button) resulted in only the...
                03-01-2025, 01:05 AM
              • battery.12v
                HP Elitebook Caps Lock Blink one time
                by battery.12v
                HP elitebook 480 G3 Blink 1 time .... Cpu Failure ... changed CPU Controller still same problem, Vcore REsistance after raising pin coils is 5 Ohm,and Diode mode 0.003 constant result even when reversing probe prolarity on Vcore CPU ... and OL on Controller side
                is this a measurements of Dead CPU ?
                07-23-2020, 01:49 PM
