W25Q128JVPQ HP BIOS Read Help
  • krawat274
    • Jun 2020
    • 53
    • Poland
    Hello everyone. I have two Winbond chip: 25Q64JVIQ and 25Q128JVPQ. Please tell me, how can I read them? Is any adapter for programmer? I have programmer TL866CS with SOP8 socket, but I'm afraid it is not compatible. Photo of chip in attachment. Thank you.
    • 21927
    Re: W25Q128JVPQ HP BIOS Read Help
    The chips are WSON8 ,you would need an adapter if you desoldered them.You can also get WSON8 and sop8 pogo pin clips.You can solder wires to the empty sop8 pads as well. The 2 bios chips aren`t supported by the TL866CS ,the latest TL866II does.The only way around it, if its the only progrmmer you own,is to find a cross compatible bios chip from another maker and check if its in the TL866CS support list, then program it as that.
    https://www.gigadevice.com/products/...e-search-tool/
    https://www.macronix.com/en-us/produ...ce-search.aspx
    https://www.micron.com/support/tools...reference-tool
    • krawat274
      • Jun 2020
      • 53
      • Poland
      Thank you for reply. I would like to buy TL866II Plus programmer with adapter, which photo is in attachment. Will it be compatible?
        • 21927
        The TL866II is a good programmer,i have the old TL866CS too.Yes that adapter is ok, you can buy it seperately at aliexpress,ebay very cheap.
        • krawat274
          • Jun 2020
          • 53
          • Poland
          Okay, thank you very much for your help.
          • STKR123
            The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
            by STKR123
            Greetings badcaps community,
            I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
            So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
            Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
            I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
            These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
            I learned that desoldering...
            10-29-2024, 06:03 AM
          • hotcrossedbuns999
            M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
            by hotcrossedbuns999
            My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
            1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
            2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
            3. I could only locate two chips that look like bios chips. Could someone verify this
            01-03-2025, 12:32 PM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • zlr8r
            looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
            by zlr8r
            looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
            cheers
            Dell Inspiron 17 (7786) Laptop
            Service Tag: 5J0NHT2
            Bios: 1.9.0
            MOBO: RO 15 17 WHL 2GB MB / 18706-2
            Attached;
            1. My saved bios using a programmer
            2. Dells Bios updater .exe (v1.16)
            3. Dells Bios recovery file
            4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
            5. Image of ME...
            12-18-2023, 03:08 PM
          • Vesko356
            by Vesko356
            08-11-2023, 03:27 AM
