Clevo n870hc / No boot
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Clevo n870hc / No boot
    PU16 test pin 1 17 22 21 20 19 voltage , check the PAD again on continuity mode, check PC237 PC86 any short & PQ42 PQ43 S D G for short
    • cdgold3
      • May 2018
      • 23
      • Cleveland
      Right, Found a 5v feed on Q49 pin 2/3 and on r699
      • cdgold3
        • May 2018
        • 23
        • Cleveland
        Was working around PU16 before you posted
        as VVD3 is working with 3.3v and measuring the pins i get:
        pin 10 - UGATE2 4.47v (Guessing trigger votage?)
        pin 12 - LGATE2 0.03v (Guessing trigger votage?)
        VVD5
        pin 21 - UGATE1 0.00v
        pin 19 - LGATE1 0.00v
        • cdgold3
          • May 2018
          • 23
          • Cleveland
          pu16 test pin 1 17 22 21 20 19 voltage , check the pad again on continuity mode, check pc237 pc86 any short & pq42 pq43 s d g for short
          1 - 0.00
          17 0.08- 0.09
          19 0.00
          20 0.00
          21 0.00
          22 4.49
          • Techtiger
            • Oct 2014
            • 1602
            • france
            Make sure PR345 62K ,PC235 is Good ,PQ42/43 S D G you must test, remove PC 237 to see if you get 5V but don’t trigger
            • cdgold3
              • May 2018
              • 23
              • Cleveland
              #26
              Hi tachtiger,
              Really appreciate your help
              Last night i found that there was no VREG5 on pin1 on PU16.
              I tracked from Q49 Pin 2 to R700 and got 4.47v. Unfortunately i may have caused a shorted something when looking at PC235. So now i have a short to ground on the 19v rail.
              Before the above i removed PQ43 and PQ42 and they seemed ok. just they are not getting a signal to trigger.
              I tried removing both U16 and PC235 and still got the short. So at the moment i am now tracking the 19v short but i think its coming from the right bottom of the board. If i ground and touch pc225, pc223, pc211 and pc222 i get ground on both sides.
              I have removed pc225, pc223 and still get the short but i am still looking.
              Testing say pc242 and C763 there is ground only to one side so the issue maybe in just that area.
              I followed this blog in testing the PU16 just to see what was going on
              https://www.leakymosfet.com/blogs/ne...aulty-tps51125
              • cdgold3
                • May 2018
                • 23
                • Cleveland
                #27
                PQ39 was faulty, now have 19v again
                • cdgold3
                  • May 2018
                  • 23
                  • Cleveland
                  #28
                  after replacing PQ39 that fixed the short to AC but i found another on PC221,PC222
                  After removing PJ44 short disappeared from side 1 but side 2 is still to ground.
                  I cant work out where side 2 connects to. Can anyone point me in the right direction?
                  • privato89
                    Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                    by privato89
                    I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                    Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                    Let's begin:
                    Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                    03-26-2024, 06:37 AM
                  • BTubbs200
                    Dell Latitude 5420: No charge, no boot; amber LED for as long as the power button is held.
                    by BTubbs200
                    Dell Latitude 5420 P137G
                    Board model LA-K491P REV A01
                    Laptop is stone dead and only reacts to the power button being held while the charger is plugged in, in which case a dim amber LED fades in and immediately fades out when I let go. Battery being plugged/unplugged does not change anything.
                    CMOS battery was removed and reinstalled; no change.
                    No shorts to ground have been identified on the board whilst probing the power rails in resistance mode. No visibly damaged components.
                    No indication that the CPU is receiving power; CPU fan does not activate.
                    Of...
                    01-23-2025, 10:45 PM
                  • Luke Anders
                    Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                    by Luke Anders
                    A few details about the laptop itself:
                    Name: Lenovo Legion 5
                    Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                    BIOS Version: GKCN60WW
                    EC Version: GKEC65WW
                    Serial Number: PF39AQ7Z
                    Board Model: NM-D562 Rev 3.0
                    RAM: 16GB Installed, DDR4 (brand new)
                    NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                    I bought this laptop recently from eBay as a faulty device....
                    10-12-2024, 05:13 AM
                  • hinisa
                    Xiaomi router freezes at boot after re-capping
                    by hinisa
                    I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                    When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                    After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                    Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                    07-08-2023, 05:58 AM
                  • NolesFan
                    Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                    by NolesFan
                    Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                    10-24-2024, 06:36 PM
