HP LA-E801P power off after few sec
  • mferna14
    • Jun 2018
    • 1046
    Re: HP LA-E801P power off after few sec
    Thanks all., I physically removed TPS51225C (which was also getting hot) Injected 3 volts on VREG3, & KBC KB9022Q gets hot.. Similar problem was with the other board too. I replaced the KB9022Q but still the new chip was getting hot. I think the problem lies somewhere else. The only difference was when I removed KB9022Q I checked the resistance on the Caps & it was normal NOT 2 ohms, but when I soldered KB9022Q back again the caps again showed 2 ohms resistance. Something within this circuit is faulty which cannot figure. Hope I get a Schematic to check when about this circuit leads too.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Remove the kbc again, clean the pads and re-measure resistance on VREG3. Still put 3V on vreg3 from bench psu and see the consumption and what is getting hot. Most likely PCH part of SOC will heat up.
      PS:You can apply power safely without kbc.
      • emestee
        • 228
        LA-706p is supposedly the closest model.
        • classicandy
          • Apr 2018
          • 309
          • Nigeria
          If PCH part of SOC heats up, does that mean PCH is faulty? Or it's possible for SOC to heat up (maybe a little) and still not be faulty?
          • emestee
            • 228
            Originally posted by piernov
            Inject 3V on VREG3, burn your finger on the PCH, cry.
            FYI this is a timeless classic now.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              #26
              Could be yes but most often its the faulty PCH, If PCH is heating up. In some rare cases you may find a cap on the back of pch faulty or a cap shorted in RTC area of pch but those cases we come across very rarely. 99% of the times its pch itself being bad. If the board comes from earlier service, i do check that first as very often pch is damaged by service attempt by people without much skills and knowledge.
              • mferna14
                • Jun 2018
                • 1046
                I cannot believe, same problem in both board, but in this one KB9022Q was shorted but in the other one there is something else wrong. Programmed the chip & all works fine.... Thanks for all the help.. (:-
