HP Stream 14-CB161WM 3F0 error
  • MicroSMD Lab
    • Sep 2018
    • 145
    • Trinidad and Tobago
    Hello, need some help with an HP stream DA0P9CMB6C0 board. The hard drive is not recognized and storage test does not commence. Keyboard and screen works.
    Board is in pristine condition, no obviously damaged components. Not sure where to start testing..... I'm thinking I should power up with the DC IN jack and test the coils for voltages?
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    Re: HP Stream 14-CB161WM 3F0 error
    streams are budget pc of HP.. do you see hard disk on it? mine only have 64gb of emmc .all are built in including the memory processor video. just re sit all the connectors...hope this helps..
    Never stop LEARNING because life never stops TEACHING!
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      if you see ssd on it just reinsert it if its been modified..
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        or your ssd or hard drive is defective.. try to run your storage device on other working pc if its been detected or not
        • MicroSMD Lab
          • Sep 2018
          • 145
          It has a 32gb eMMC. Already reseated all the cables and reflowed the sandisk chip and no difference.
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            if you can get to the bios your memory, lcd, processor is good if you cannot get to the drive your emmc may gone bad or maybe its not detected by the bios.. disconnect the battery to reset the bios and try again.. do you have pcie ssd drive you can connect it via the mini pcie just disconnect the wifi card.
            • Duranitron
              • Jul 2014
              • 544
              • Philippines
              this emmc is also built in the board..you need equipment to take it off the board.. try the ssd drive to mini pcie slot to check if it can boot to ssd. good luck ,,, may the force be with you..always,,,
              • MicroSMD Lab
                • Sep 2018
                • 145
                Thanks for all the help! I will try that, do I need to use a m.2 drive?
                • Duranitron
                  • Jul 2014
                  • 544
                  • Philippines
                  mine doesnt have m.2 connection u need ssd with mini pcie connector or converter.
                  • MicroSMD Lab
                    • Sep 2018
                    • 145
                    Got it, thanks!
                    • Sus256
                      HISENSE 65E7KQ PRO - no boot
                      by Sus256
                      Hi all!
                      HISENSE 65E7KQ PRO
                      RSAG7.820.13512 - chassis
                      MT9618BAATAB - cpu
                      RSAG7.820.12059 - power
                      HD650Y3U77 - panel
                      KLM8G1GETF - emmc
                      The TV does not turn on, the standby indicator is on. All voltages are present.
                      Emms is dead. Not readable, not detected.
                      Replaced emmc.
                      But with another dump there is no launch
                      Terminal log
                      UART
                      AC_ON
                      RPMB key is not yet programmed
                      HASH1_VERSION=0x00000000 64bit
                      E-B
                      FDE enabled
                      layout pattern onebin by SAR7,0...
                      06-01-2025, 02:11 AM
                    • Superbee_dad
                      Sharp 80” long short flash backlight error - Help
                      by Superbee_dad
                      Hello Sharp TV experts
                      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                      01-24-2025, 11:51 PM
                    • Curtissimo
                      HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                      by Curtissimo
                      Hi everyone.
                      I have a HP Elitebook 850 G8.
                      Serial: 5CG2324XM0
                      ProdID 6L8D5EC#ABA
                      It has a Winbond W25Q256JVEN Chip.
                      I need to remove BIOS Password.
                      I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                      Attached my dump.
                      I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                      I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                      What I did:...
                      08-26-2025, 04:42 AM
                    • Maalobs
                      Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
                      by Maalobs
                      I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
                      The relevant service manual for the chassis is available here.
                      The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
                      When I short the SDM to ground I get the layer-2 error code 53.
                      The inside of the TV has no damaged components and no swollen capacitors.
                      In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
                      04-02-2019, 01:15 PM
                    • josel
                      HP Stream 14-cb163wm DA0P9CMB6C0
                      by josel
                      Hi.
                      I need schematic and boardview, if available, for HP Stream 14-cb163wm, MB DA0P9CMB6C0 REV:C.
                      Thanks.
                      06-04-2022, 12:00 PM
