Laptop shutting down and refusing to restart till some time passes
  • Qattos
    • Oct 2017
    • 18
    Laptop : Lenovo Y520 i5-7300HQ 16GB RAM GTX1050Ti 240GB NVME SSD 1TB HDD.
    I bought my laptop in 2018, the guarantee ended in May of this year, it's been working(mainly gaming) fine for all this time except a minor issue with Windows warning me about power surge on USb port all the time when gaming, and it wasn't my mouse, I tried another mouse and the same issue, so I thought it's a driver problem and just ignored it.
    My real issue:
    My laptop appeared to be shutting down randomly at first, and when I try to restart it, the keyboard lights turn on, the HDD makes its usual starting sound and I can hear the two fans spinning, my mouse lights on as well, but the screen stays black, nothing happens for 5-10 seconds then the laptop shuts down totally, keeps doing this if I insist on turning it on, I stop trying and leave it be for a couple minutes, not sure exactly how many it needs, then come back and turn it on and it's working again, it loads everything, windows 10 starts, everything looks to be working fine, I wrote this post using my laptop, then once I open Lenovo Nerve Sense (a software that controls fans speed and some hardware), my laptop shuts down again, same story happens, leave it for a bit, come back it works again, this time instead of opening Lenovo Nerve Sense, I open Lenovo Vantage (another software that controls my laptop hardware), you guessed it, my laptop shuts down, same story, leave it then come back, it starts as usual, this time I run Lenovo's diagnostic tool, finds no issues whatsoever, I even made a bootable USB from it, managed it to run it when my laptop boots and it found no issues as well, you might think it's a temperature issue, nope, never had that, even while gaming my CPU, GPU never go passed 65C, my SSD and HDD never go passed 35C, my RAM sticks never go over 60C, and I used to run my fans at max speed all the time, I enjoy their noise.
    BTW, I can even still game of my laptop (played Bannerlord before writing this), everything runs butter smooth.
    My laptop's history:
    I undervolted my CPU and Nvidia GPU for over a year and it was always stable, so this wouldn't have been the issue, temps were always fine, even now, I did once overclock my display to 62hz then took it back to 60hz, this can't have been the cause because my laptop worked fine afterwards for months.
    My capslock key one time stopped working when I click it, but its backlight turns on when I enable capslock from the On-screen keyboard, that was weird.
    My troubleshooting:
    Removed SSD, same issue.
    Removed HDD, same issue.
    Removed both SSD and HDD, same issue.
    Removed one RAM stick, same issue.
    Removed the other RAM stick and put the other in, same issue.
    Switched their positions, same issue.
    Cleaned the fans, same issue.
    Removed Battery, same issue.
    Disabled secure boot, same issue.
    Disabled fastboot, same issue.
    All my drivers are up to date, same issue.
    Lowered my undervolt, same issue.
    My guess:
    - Fans are the cause.
    - Keyboard is the cause somehow.
    - Maybe some capacitor is losing it, hope not.
    What do you think?
    Any help is appreciated.
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Laptop shutting down and refusing to restart till some time passes
    Time to open up the power brick!
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Qattos
      • Oct 2017
      • 18
      What power brick? And why do I get the feeling you're trolling? :'(
      • RJARRRPCGP
        • Jul 2004
        • 6304
        LOL! I mean the power supply.
        Arc A770 16 GB
        • caspian
          • Oct 2015
          • 1589
          • Laptop
          There are many potential faults that can cause this shutting-down problem. When the problem happens, measure voltages on the AC adapter and on the mainboard using a multimeter.
          • Qattos
            • Oct 2017
            • 18
            Oh
            Well, doesn't having the same issue when using the battery mean it's not because of power supply? Please elaborate if I'm mistaken.
            • Qattos
              • Oct 2017
              • 18
              Originally posted by caspian
              There are many potential faults that can cause this shutting-down problem. When the problem happens, monitor voltages on the AC adapter and on the mainboard using a multimeter.
              I'll get a multimeter tomorrow and put everything I learned from a bunch of Youtube videos into practice.
              But I'm a bit confused, or maybe ignorant, isn't having the same issue when only booting from battery means it's not a problem with the AC adapter?
              • caspian
                • Oct 2015
                • 1589
                • Laptop
                It is only a probable guess. Measuring the output voltage of the AC adapter is the best way to test it. Measure the output voltage both when the problem happens and does not happen. But probably, the fault exists on a component on the mainboard.
                • Qattos
                  • Oct 2017
                  • 18
                  I will do that and I do think it's some faulty component on the main board, which is why the laptop turns on and works normal after taking a rest, logically this would mean overheating but the temps are below 65 under heavy load.
                  Thanks for your time.
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Oh
                    Well, I would then attempt to check for caps that aren't in spec on the motherboard then.
                    Arc A770 16 GB
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      open the laptop and take out the motherboard. Look carefully for any corrosion,rusted element on the motherboard. Clean it with isoprpyl alcohol. May be some cold solder somewhere.
                      • Qattos
                        • Oct 2017
                        • 18
                        I got a multimeter and started measuring caps while checking the schematics of the mo-bo, but it's quite confusing, so many symbols and ways of testing different components, some components are so tiny I avoid touching them for fear something might happen to them.
                        I'm at a loss right now.
                        • caspian
                          • Oct 2015
                          • 1589
                          • Laptop
                          Measure voltage on big coils and the AC adapter only. Measuring small components has the risk of shorting them. To measure capacitors, you should desolder them from the mainboard.
                          To learn how to measure voltage, search for videos on "laptop voltage measurement".
                          • Qattos
                            • Oct 2017
                            • 18
                            I took the motherboard out, my eyes hurt from looking at it and its tiny components, I didn't notice any corrosion or rust, but wait a second, is it normal behavior for the laptop to sometimes work and sometimes not even show anything on screen if its motherboard components have some corrosion or rust? I'd guess it should not work at all if it has corrosion or rust, right?
                            When I boot it up and it shuts down after around 5-10 seconds, during this brief time the fans are turning, keyboard and its backlight are working, the HDD makes its usual sound, my mouse lights up, but the display stays black, if logic is to be used here I'd say the cause of these boot up failures happens somewhere between all those components I mentioned working and the display receiving a signal to work as well, so I disconnected the display cable from its port on the motherboard and the boot up failure persists, meaning the display is not the issue, but something along the way to the display is causing these failures, I don't know, I could be talking gibberish.
                            I have the schematics of my motherboard but I'm too slow in my attempts to understand them.
                            One little addition is that when I posted this I was able to boot up at one point and I even stressed my CPU and GPU with a game reaching 70c temps and nothing crashed, so, WTF is going on
                            • caspian
                              • Oct 2015
                              • 1589
                              • Laptop
                              My eyes are becoming weak due to aging. I have to use a Magnifier or Microscope to look at mainboard's components.
                              No, corrosion can cause intermittent faults.
                              You have to discover what operations on the laptop cause the shutdown and what operations does not.
                              • Qattos
                                • Oct 2017
                                • 18
                                The AC adapter is working as it should, 20.6v.
                                As for big coils, I don't know how those look, I'll check the schematics.
                                I'll avoid measuring small components, I hope it's not too late because I touched some of them
                                And thanks for your time and recommendations, I am watching Louis Rossmann videos and a guy called Sorin, trying to learn.
                                • Qattos
                                  • Oct 2017
                                  • 18
                                  Oh, that could be it then.
                                  If only the owners of badcaps would accept boards from my country, I'd send it to them, but they only accept from US and Canada.
                                  Anyways Thanks again, I'll report back once I have news.
                                  • caspian
                                    • Oct 2015
                                    • 1589
                                    • Laptop
                                    Big coils are the cubic gray components on the mainboard.
                                    • pfrcom
                                      Oldbie
                                      • Jun 2006
                                      • 1230
                                      You could try contacting
                                      https://www.badcaps.net/forum/member.php?u=21626
                                      who is also in Bucharest
                                      better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                                      • Kambi13
                                        MacBook Pro A1297 Shutting Down Issue
                                        by Kambi13
                                        Hi all, a few months ago I had a MacBook Pro A1297 mid 2010 that came in for new SSD drive and full system and cooler cleaning with fresh thermal paste being applied (Arctic MX4).
                                        Has been working fine, but now, out of the blue, here's what happens - It does boot up normally but after 10 ~ 15 seconds it turns itself off, either with the battery or with charger plugged in.
                                        Now weird part is that, although the fans do spin, I feel the cooler start to heat up very quickly, and of course that's why it's shutting itself off, overheating issue. But as I stated before it's completly clean,...
                                        10-27-2022, 04:23 AM
                                      • rounin
                                        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                        by rounin
                                        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                        🛠 Original Issue
                                        The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                        04-19-2025, 01:18 AM
                                      • ugamazing
                                        Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                        by ugamazing
                                        I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                        We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                        12-17-2024, 07:05 PM
                                      • elmark
                                        HP 15-cw1002ua strange keyboard issue
                                        by elmark
                                        HP Pavilion 15-CW1002UA
                                        S/N 5CD0251CBC
                                        P/N 7KE54EA
                                        Hello guys!
                                        I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                        It powers on OK and has no other issues except the following:
                                        • CAPS LOCK does not work at all
                                        • Fn button toggles Flight Mode
                                        • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                        • (with SHIFT pressed: 't%' and 'y^' respectively)
                                        I initially thought it was a keyboard malfunction (internal short, etc.),
                                        but when I press and hold...
                                        06-27-2025, 01:10 AM
                                      • Simone Vergani
                                        Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                                        by Simone Vergani
                                        I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                                        To assist with troubleshooting, I'm attaching two power circuit schematics:
                                        • Power
                                        03-05-2025, 02:25 PM
