iPhone 7 keeps restarting infinitely
  • WhiteWolfHellas
    • Jun 2019
    • 95
    • Greece
    Hello, I have an iPhone 7 that is stuck in a bootloop. After the Apple logo, screen turns off and it restarts in a loop.
    If I remove the front camera/proximity sensor the problem goes away and the phone turns on normaly. I replaced the front camera with a new one but the problem returns again.
    I would apreciate any help.
  • WhiteWolfHellas
    • Jun 2019
    • 95
    • Greece
    Re: iPhone 7 keeps restarting infinitely
    Ok, after some more testing I figured out that the cracked home button was the problem. Can it be replaced?
    • deepak1981
      • Jun 2020
      • Spain
      hi, search for jc home button for ip 7 , but replacing home button would mean you would lose your touch id.
      • mon2
        • Dec 2019
        • 13948
        Hi. Do watch the videos here on the topic:
        https://blog.puls.com/iphone-7-loop-disease
        This guy discovered the fault and Apple had a class action law suit against them that covered the repair costs for at least the iPhone 6 I believe.
        If I recall correctly, the issue is that over time, the audio ic becomes undone off the pcb due to the pcb layout and where the audio ic is located. Due to repeated stress in this part of the pcb, the audio ic is no longer able to communicate with the host i2c interface. The host i2c controller then keeps retrying / looping the os to find this missing audio ic.
        Your issue could very well be the same. Many videos on this fault and repair on youtube.
        I would suggest that you contact this same repair shop to ask for their advice. I believe that he is in Spain. Kudos to him for this discovery.
        Please do update this thread with your progress.
        • RethoricalCheese
          • Mar 2013
          • 1517
          • Estonia
          Audio issue phones have not bootlooped for over a year now, unless the phone has a very old iOS on it.
          Audio IC itself doesn't get loose. Only one certain trace gets a microfracture and that's enough for it to stop working.
          • Yeritan21
            • Mar 2021
            • China
            Oh. Hope you solved your question.
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
            • Stephen
              MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
              by Stephen
              MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
              03-15-2024, 09:37 AM
            • www
              LG L192WS-BN backlight turns off after 1 second
              by www
              I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
              I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
              03-24-2024, 05:26 PM
            • andrhouseolly
              Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
              by andrhouseolly
              Hi.
              I kindly ask you to help me solve the problem.
              Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
              The board turns on, there is no image.
              Read more. When the power supply is connected, the front panel indicators light up briefly.
              When you press the power button, the button indicator lights up. The board works
              there is no image, there is no matrix initialization, there is no image on HDMI.
              When turned on, the fans do not spin, but when they warm up they start spinning.
              When you turn off the button, the fans spin up to full speed for a short...
              05-11-2024, 03:14 PM
            • Egidio85
              Samsung UE55F8000SZ Turns on and off immediately
              by Egidio85
              good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
              This defect happens continuously, hearing the classic click of the relay every time.
              Power supply board BN44-00636B
              disconnecting the mains and lamps from the power board always causes the same problem.
              Is it normal that without anything connected this power supply turns on and off cyclically?
              any suggestions on what to check?
              thanks in advance
              03-11-2025, 12:45 PM
