MacBook A1278 820-2936-B SATA HDD Not Detected
  • j5p332
    • Jun 2020
    I was asked to look at a coworker's A1278 MacBook. Logic board is 820-2936-B. The laptop boots to question mark. Drive mounts fine on another MacBook, tried a new SSD with the same result. Pins in the drive end of the flex appear to be in good condition. Inside of the device was very dusty with lots and lots of cat hair.
    Recommendations on what to check would be most appreciated. I have a microscope, oscilloscope, budget fluke multimeter and soldering station on hand. Some additional items such as a bench multimeter, frequency counter, vsa at home that could be brought in.
    Thank you so much,
    Justin
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: MacBook A1278 820-2936-B SATA HDD Not Detected
    Did you try another hdd flex i got the same problem couldn't see any damage measure the flex and all was good but still the flex was bad tried another and the hdd was recognized.
    • piernov
      • Jan 2016
      • 4439
      • France
      Tried PRAM reset? Any liquid damage?
      Drive doesn't show up at all in Disk Utility (even after changing view mode to all devices/partitions rather than just volumes) when booted in Internet Recovery or from USB installer?
      If drive doesn't show up at all, try another SATA cable.
      • Abu Ali
        • Aug 2019
        • 15
        • Denmark
        The HDD flex cable is well known problem on these A1278 models.
        It has a sharp 90 degrees bend where it is screwed to the chassis. When the HDD uses high current for the life of it, it get damaged at this point.
        • DynaxSC
          GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
          by DynaxSC
          I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
          There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
          The board is generally working now, all PCIe ports are working, Windows installs normally.
          However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
          The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
          03-10-2025, 12:27 PM
        • Adogabriel100
          Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
          by Adogabriel100
          Hey! This is a A1278 macbook 2011.
          Problem: Not turning on / No green light
          Im using by3200s charger.
          Voltajes:
          PPBUS_G3H = 12.26v
          SMC_RESET_L = 3.3v
          PP3V42_G3H = 3.42v
          U7000 =
          Pin 1 CHGR_AGATE = 0v
          Pin 2 CHRG_DCIN = 19v
          Pin 3 CHRG_ACIN = 4.6v
          Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
          Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
          Pin 12 PP3V42_G3H = 3.42v
          Pin 13 CHRG_RST_L = 3.3V
          Pin 14 SMC_BC_ACOK = 0.8V
          Pin 19 PP5V1_CHRG_VDD = 5.05V
          Pin 20 PP5V1_CHRG_VDDP = 5.03V...
          04-01-2024, 01:02 PM
        • Rezendes
          Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
          by Rezendes
          Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
          I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
          The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
          05-10-2024, 02:18 PM
        • pcbmaniac
          MacBook A1278 (3115) No PPBUS_G3H Issue
          by pcbmaniac
          Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
          I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
          1. U7000 Measurements:
            • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
          2. Resistors:
            • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
          Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
          • If I also decide to replace the SMC, do I need to order it pre-programmed,
          12-02-2024, 04:12 PM
        • sizar00740
          macbook pro 13 inch a1278 820-2879
          by sizar00740
          please clear me this bios efi macbook macbook pro 13 inch a1278 820-2879...
          07-30-2025, 10:21 AM
