PCG-71316L does not turn on
  • khelane
    • Apr 2015
    • 159
    • xxxx
    Hi
    PCG-71316L
    MBX-223
    this device does not turn on.
    PU19 gets hot. change it and hot gain.
    check ohm PL17 / PL16
    PL17 0.946k ohm
    PL18 25k ohm
    i took out PL17 and again checked ohm . side on the ic PU19 ohm 10k or above but other side(consumer) PC199 : 0.946k ohm
    when i enject 3.3volt in consumer side (PC199) for 1 second go high 0.18 amp and immediately 0 amp and not flow amp in circuit and not hot device .
    in last sorry about my english .
    tnx
  • silentbogo
    • Jun 2020
    • 8
    • Ukraine
    Re: PCG-71316L does not turn on
    Does PU19 get hot immediately after you plug in the charger or battery?
    Did you check other rails (+5VALW_LDO, +12V)? Maybe PU9 is short?
    • khelane
      • Apr 2015
      • 159
      • xxxx
      yes when i plug charger pu19 immediately get hot.
      +5VALW_LDO not shorted
      +12 no shortd .
      just +3VALW show low ohm 0.945k(anormal). side of pc199 or TP219
      • khelane
        • Apr 2015
        • 159
        • xxxx
        i enjected 3.3 volt in +3alw (pc199 or TP219) showing 0.18 amp for milisecond and go to 0 amp!
        somebody have any idea?
        • pajdek
          Lenovo Y700-17ISK turn on and off
          by pajdek
          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
          09-20-2023, 02:49 AM
        • RdeveLabs
          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
          by RdeveLabs
          To all the members here...
          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
          05-05-2025, 04:59 AM
        • robante15
          Acer Aspire 4520 won't turn on after reboot
          by robante15
          Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
          It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
          The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
          If I remove the...
          04-06-2024, 06:50 PM
        • masoksian
          Dell latitude e7470 not turn on .power buton on off and Run Power problem
          by masoksian
          I am dealing with the problem of turning on and off my Dell e7470 notebook.
          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
          The system does not turn on, there is no post.
          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
          The problem continues in the same way.
          I tried to turn on the Fn key, nothing came to the screen....
          02-15-2025, 12:08 PM
        • dqtech
          lenovo x240 nm-a091 wont turn on
          by dqtech
          i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
          board number VIUX1 NM-A091 REV:1.0...
          02-07-2024, 01:57 AM
