Macbook Air 820-00165-A
  • moderator
    • May 2020
    • 33
    • India
    i am new here and i am noob...i have macbook air...same model what we are discussing here...its kind of dead...when i plug it in the there is green light..which stays green..when i disconnect the battery and then when i plug in then i get green light which turns to orange.so i opened the board to inspect...board was clean..there was no liquid damage.only near U5000 there was one resistor...r5117..which had sulphur ..so i cleaned it with isoprphyl..gave little heat..than tried to use soldering iron on both side of the resistor also..
    now the situation is almost the same..fan spins for sometime..goes to high speed then turns off...sometime fan doesnt even spin after connecting the power..though the power ligh is still there in charger...
    any help will be appreciated...
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Macbook Air 820-00165-A
    Go down the list of power rails and report voltage.
    Also history of the machine always help.
    • moderator
      • May 2020
      • 33
      • India
      thank you for your prompt reply...thanks for being so active here and actively helping people..
      i got my solution..r5117 got knocked off while cleaning the board more..so i saw there was still sulphur below the resistor..and wasnt getting any track..so then i took 100 k resistance from another donor board..put it there..
      though i couldnt find the track below one of the point of the resistor..so i created a track from different point..and voila..
      i connected power..could feel the heat on heatsink..connected all wires..and now apple logo and booted
      • envym
        by envym
        Hi everyone!
        06-27-2025, 08:54 AM
      • Flasman90
        Macbook Pro DFU Restore Issues
        by Flasman90
        I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
        - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
        - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
        08-30-2025, 10:27 AM
      • tobeend
        Bypass mdm macbook m2 ventura
        by tobeend
        1. RESET MACOS WITH IPSW
        a. Power off MacBook, press and hold the power button to enter Recovery
        b. Open Disk Utility, remove Macintosh HD
        c. Reboot, connect to the network to Activate Mac.
        d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
        d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
        e. Release the other keys, but keep holding the Power key for another 10 seconds
        f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
        05-26-2023, 07:18 AM
      • SarcasticOP
        General question about MacBook power rails for repair.
        by SarcasticOP
        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
        • PPBUS_G3H (12.6V-12.8V)
          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
        • PP3V42_G3H (3.42V)
          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
        • PPVRTC_G3H (3.3V)
          • This
        12-12-2024, 05:50 PM
      • obelix24
        A2941 Macbook air 15” - 5V 0a
        by obelix24
        I’m working on one macbook air 15” m2 that was water damaged.
        keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
        i’ve put macbook in shelf and order new screen so i can fully repair it.
        Now i got the screen and macbook stays at 5v 0a.
        i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
        i don’t have schematics so i don’t know where to start can someone help me?...
        03-27-2025, 01:19 PM
