UX303UB Power Sometimes / No Video
  • ngen33r
    • Sep 2016
    • 24
    I am trying to troubleshoot a power issue on this board. I did find a burned 0R resistor. I removed the burnt jumper resistor and replaced with a solder ball. Symptoms are CPU and GPU get hot with power off and adapter in.
    R2614
    1 +3VA_DSW
    2 +3VDSW_VCCPDSW
    I am starting to test the rails in the repair guide.
    +3VA_RTC = 3.054V
    RTC_RST# = 3.052V
    +3VA_EC = 3.296V?
    EC_RST# = 3.285V
    3VADSW_ON = 3.363V
    +3VA_DSW = 3.352V
    +5VSUS = 5.089V
    DPWROK_EC = 3.287V (INTERMITTENT WITH POWER ADAPTER)
    PM_SLP_SUS# = 2.54V?
    VSUS_ON = 3.295V
    +1.0VSUS = 1.030V (PL8302 GETS HOT VERY FAST, HIGH CURRENT DRAW?)
    PCE3802 READS 0.5OHM FIRST ISSUE LOCATED
    +1.0VSUS SHORT TO GND
    +1.0VSUS_PCH SHORT TO GND
    +VCCMPHYG SHORT TO GND
    +VCCIO SHORT TO GND
    R0601 REMOVED
    VCCIO_CPU SHORT TO GND
    SHIT....CPU IS FRIED
    BGA $199 - SCRAP BOARD DAMN
  • flavioteuy
    • Jul 2020
    • Uruguay
    Re: UX303UB Power Sometimes / No Video
    Don't feel alone. I am having the exact same problem here. My computer never start.
    I have replaced the LCD+Touch, it worked, then i tried to check my old LCD (without connecting touch controller and camera), and the laptop entered this state.
    When i plug in the computer with charger, or turn it on with battery, it tries to start, and:
    LCD backlight flash (and black screen after).
    Power Button Led turns on.
    CPU HeatPipe goes hot, very hot.
    PL8302 gets hot very fast also.
    Fan doesn't start.
    Did you resolved this issue? What can i start checking?
    Thanks in advance,
    Flavio.
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      try first to reflow the processor before you scrap it...
      Never stop LEARNING because life never stops TEACHING!
      • DynaxSC
        Extreme High Current & Low Voltage Short Killer ??
        by DynaxSC
        Hi Folks
        I'm looking for a extreme high current short killer solution for a reasonable cost.
        I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
        After taking off the socket, the shorts dissappear again.
        The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
        10-15-2024, 10:13 AM
      • Stephen
        MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
        by Stephen
        I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
        02-06-2025, 12:03 PM
      • Victor Moreira Silva
        Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
        by Victor Moreira Silva
        I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
        Well, my decice specs are the following:
        Model: Acer Nitro 5 AN517-54-55T5
        CPU: Intel Core i5-11400H
        GPU: NVIDIA GeForce GTX 1650
        Motherboard: GH51G LA-L181P Rev:1c
        The symptom:
        When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
        05-26-2025, 10:49 AM
      • aaronkatrini
        Help me find the short circuit on this WORKING Nvidia GTX1650
        by aaronkatrini
        Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
        Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
        04-18-2024, 03:15 PM
      • Geeker007
        9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
        by Geeker007
        Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
        I am new to electronics repair, so my queries could be naive but I am ready to learn.
        So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
        01-28-2025, 03:31 PM
