Bad Laptop PCH?
  • Spider1211
    • Oct 2019
    • 532
    • Mauritius
    Re: Bad Laptop PCH?
    Tried other BIOS and EC as obtained upon request. No luck, still same issue.
    • emestee
      • Dec 2019
      • 228
      • Bulgaria
      Re: Bad Laptop PCH?
      Hold on, you said pin 7 is pulsing, and pin 7 is hold signal? That is not normal at all, is the PCH resetting continuously? Maybe a good time for a scope on the rest of its signal lines?
      • Spider1211
        • Oct 2019
        • 532
        • Mauritius
        Re: Bad Laptop PCH?
        Yes, it is. Pulsating only in OFF state, its a steady 3.3V once laptop is turned ON. As for the PCH resetting, I am not so sure since all the signals coming out of the PCH (as per repair guide) are stable.
        Which signals? The once where you would expect to see activity (LFRAME, etc) shows none. Any suggestion as to which I should test/scope?
        • emestee
          • Dec 2019
          • 228
          • Bulgaria
          Re: Bad Laptop PCH?
          Frankly I am out of my depth here. This is definitely not supposed to happen, and if the PCH is doing that, it's either because something causes it to reset repeatedly, or an internal damage to the chip. It is possible that some passive element around it is broken and causes a power reset or something like this. But I dont know how to debug this other than oscilloscoping the hell out of it looking for clues.
          • Spider1211
            • Oct 2019
            • 532
            • Mauritius
            Re: Bad Laptop PCH?
            Update:
            Am definitely sure issue is now PCH related. The replacement PCH ended up being faulty. I am still waiting on receiving another replacement but in the meantime I got a donor board with an almost similar chipset.
            More info here: https://www.badcaps.net/forum/showthread.php?t=88548
            I tried it out of curiosity (and also hoping it would work) but no dice. I do however now have healthy BIOS signal at start up.
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              #26
              Re: Bad Laptop PCH?
              Originally posted by Spider1211
              Its a stable 25MHz when the laptop is turned on, please see "clock" in the first post.
              Same for X2001 which is a stable 32.768KHz both in ON and Off state.
              +V1_05S_PCH_VCC
              0V in off state
              stable 1.06V in ON state
              Sir out topic what if you dont have a 24mhz reading what will happen to the laptop , noob question sir
              • Bloodhoundje
                HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                by Bloodhoundje
                I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                I have desoldered the bios chip (GigaDevice...
                03-16-2024, 03:12 PM
              • JoWed
                Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                by JoWed
                Hello Community,
                I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                07-01-2025, 09:32 AM
              • thxd43
                Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                by thxd43
                Hello, first of all, excuse me, I am using the translator, English is not my native language.
                I have a Lenovo ideapad 330S - 14IKB laptop.
                The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                02-23-2023, 08:37 PM
              • legendkray
                BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
                by legendkray
                I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
                07-05-2025, 09:25 AM
              • AquaMan Ua
                by AquaMan Ua
                05-17-2025, 09:40 AM
