XPS 9360 Motherboard Backlight Damaged
  • mgrharry
    • Sep 2016
    • 211
    • usa
    Working on a Dell XPS 9360 motherboard, DPN T9VPC. Cust tried installing new mobo and presumably connected the battery before connecting the screen. Now system boots with image but no backlight. External monitor is fine. LCD panel itself was tested OK on another XPS motherboard.
    Does anyone have a board view for this model? Or suggestions on backlight circuit repair?
    Thanks.
    • 21874
    Re: XPS 9360 Motherboard Backlight Damaged
    Schematic requests go here:https://www.badcaps.net/forum/forumdisplay.php?f=41
    Not available b.t.w.
    • triplefour
      by triplefour
      09-13-2023, 10:43 PM
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • glovecaps
      Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
      by glovecaps
      I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
      My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
      The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
      11-25-2024, 04:23 PM
    • resistor83
      Motherboard LA-B972P it has no backlight
      by resistor83
      hi everyone, I have this hp laptop, motherboard LA-B972P that hasn't had the backlight from a few days. However, you can see the image through the flashlight but without backlight.
      I also tried to change the monitor but the backlight is not present. It can only be seen through a flashlight. So I guess there is a problem on the motherboard.
      What measurements could I start taking?
      Thank you...
      05-26-2022, 09:35 AM
    • DanPoka
      Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
      by DanPoka
      I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
      Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
      This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
      02-15-2025, 05:05 AM
