GTX1060m top capacitors?
  • myth77
    • Feb 2017
    • 380
    • Croatia
    I received asus laptop, unknown history, shorted on 19v...fixed...When i turn it on i could see picture but with dots/artifacts on the screen..and so on..Probably the reason is dead gpu but...with eye inspection i could see that more then a half of capacitors from gpu chip is missing. So, to be clear...capacitors from top of the gpu chip are missing. It looks like someone remove it by force.
    I would like to solder a new capacitors just to see if that is the problem...but i am not sure what capacitors to use...mostly not sure are they all the same capacitors?!
    So, is there anyway to know what capacitors are used on the top of the gpu? all boardviewers and schmematics are for the motherboards...and they do not show the details of the gpu chip.
    thx
  • peste
    • 12600
    • ROMANIA
    Re: GTX1060m top capacitors?
    carefully heat the GPU chip, use the flux paste and see what happens.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      Take same size capacitors from a dead GPU from the same family. They are fairly generic parts. I know for a fact a GPU should happily run with most of them removed, though.
      A working TV? How boring!
      • Weelcup
        TopTech
        • Oct 2017
        • 302
        The caps are very small and the chip has excellent thermal built which will make it very difficult to solder the caps if you do not have the right tools. Such as microscope and soldering tweezer tips. Or a bga soldering station
        I have checked some of 1060 caps a while ago and they were including 100nf and 0.1uf. But cannot recall there positions.
        • dragon3x
          by dragon3x
          power on.
          Here are some examples :
          switching supply area).
          than 6.3 V.)
          03-21-2025, 02:46 PM
        • slybunda
          AA and AAA battery charger capacitors?
          by slybunda
          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
          it has inside:
          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
          2 x 470uf 16v LZ105c branded as G.Luxon
          not heard of these brands are they any good?
          iv attached photos of the charger and the board inside for an idea on the type of...
          12-24-2023, 04:41 AM
          After all of...
          07-13-2024, 08:14 PM
        • Ady2017
          Are there any datasheets available for Elna RJG capacitors?
          by Ady2017
          I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
          05-25-2025, 02:19 PM
        • ctroxtell
          Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
          by ctroxtell
          I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
          01-03-2025, 08:57 PM
