usb c cable fix
  • ED1233
    • Apr 2020
    • Israel
    usb c cable fix
    hi!
    im new here so i hope im not doing anything off limits and that im in the right forum.
    i was trying to fix usb- to usb-c cable, for charging my laptop (macbook 12 45w).
    it stoped charging so ive opened the cable and with my attemps i cut the exposed wires, silver color and made up from many differerent wires windind around themselves. 4 wires in total.
    im uploading a picture of the remaining cable.
    the question is:
    is it fixable? its just so much more fun than buy a new one
    thanks a lot
    EYAL
  • Tr0ll
    by Tr0ll
    Original T-con:
    First replacement T-con:
    10-07-2023, 07:48 PM
  • conghuyms
    I need datasheet cable eDP LCD 30 pin slim pls help me!
    by conghuyms
    My 30-pin eDP cable from the mainboard to the LCD screen got cut and damaged at the screen connector side. I found another cable and took the screen-side connector from it, but the wire colors are different. So I really need the wiring diagram for both ends of the eDP cable to solder it back properly. If anyone has the diagram, please kindly help me out. Thanks a lot...
    08-22-2025, 11:16 AM
    ESR meter came to the rescue again today with a PLC I/O card fault
    I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
    I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
    One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
    12-18-2023, 08:17 PM
  • fweonea
    HP-Pavilion x360 Laptop Dead After USB-C Cable Connection
    by fweonea
    While at university, I connected my HP-Pavilion x360 14-dw0156ng laptop, running Windows 10, to a monitor using a provided USB-C cable. Immediately after this, my laptop's screen turned black and the device stopped working entirely. There are no signs of life such as fan noise or LED indicators, holding the power button does nothing. I've previously used this same monitor model and cable without issues, the cable typically charges the laptop as well.
    I've attempted holding the power button for over 30 seconds, removing and reinserting the battery, and trying to power it on with only the...
    01-16-2024, 11:35 AM
  • marce002
    Help me make charger USB C cable with no cc pins!!
    by marce002
    Hi all, please
    I just want to make a "usb c" charging cable from 5V power supply (have cut cable w/ red black green and white pins connected from factory.... i just want to use 500mah max !
    How do I connect this ? if I do not have CC1 /2 physically wired, how to proceed?
    NOTE: an identical new (not cut) USB A to USB C cable charges my phone but not the remote control!
    here is a picture of the remote, the cable to be used and a picture of what are the factory connected pins
    thanks in advance!!
    11-17-2023, 09:16 AM
