Gateway MX8711 laptop overheating - faulty heat pipe?
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Working on a laptop that came in yesterday. Owner complains it works for a while then shuts off. I start checking it out... It runs fine for random amounts of time. Typically, if you start it up and just let it idle in Vista, it'll run fine indefinitely. But, once you start doing something (spyware scan, for example), the computer will run for a bit longer and then shut off.
    CPU is a T2250 Core Duo 1.73ghz. I installed speedfan to check the temps. At idle, it runs about 56c. Under load, it'll touch 80c, and that's where it shuts down. It does appear that the computer shuts down properly when this happens, as the screen fades, and then it turns off.
    Now, here's what gets me to believe the heat pipe is faulty... the entire time, the fan will be running, but the vents are both blowing cool air (ambient temperature, I should say). I have, of course, checked all the fins, and they are completely unblocked. When the computer shuts down, the heat pipe around the CPU is very hot... but the actual heatsinks are barely warm to the touch.
    Should I take a leap and get a new heatpipe assembly for this thing?
    Ludicrous gibs!
  • Wizard
    • Mar 2008
    • 2296
    Re: Gateway MX8711 laptop overheating - faulty heat pipe?
    Definatly get new assembly and check that chipset heatsink are making good contact. I use ceramique by AS as it does not dry out as much as arctic silver would do and stay flexible, and not as messy, not so electrically conductive.
    Cheers, Wizard
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      The CPU and the heatsink are making good contact. I don't have any Ceramique, but I did put AS5 on, after removing the stock dried-up paste.
      Ludicrous gibs!
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        no offence, but there is a laptop section now. next time, please post it there.
        sigpic
        (Insert witty quote here)
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          Heat pipe was faulty. Got the replacement from BlueRaven on eBay and it's working fine now.
          Oh, and thanks so much for the help Mr. Rat.
          Ludicrous gibs!
          • Wizard
            • Mar 2008
            • 2296
            Excellent, that's unusual. The heat pipe is special engineering marvel that contains little amount of water and gases (could be air or inert gas) under partial vacuum so water is below it's boiling point and boils at lower temp to move vapor and heat to cooler end and radiate heat out, condensing the water back and run back to the hot end.
            Cheers, Wizard
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              My guess is that the solder joint at the end of the pipe failed and let the liquid out, as well as releasing the vacuum.
              Ludicrous gibs!
              • toastygoodness
                • Jul 2005
                • 813
                yeah so the solder joint let go? wow this is one weird failure.
                pics please? this is pretty cool (well interesting, it sucks u had to buy a new one)
                • Wizard
                  • Mar 2008
                  • 2296
                  Not totally under vacuum. Just low enough (like you are at top of mountain and water is boiling at rather low temp like 40C) due to atmospheric pressure is low.
                  Cheers, Wizard
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Interesting.
                    I've never seen one go bad.
                    Wondered why they even sell spares.
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      i have seen several fail in hp laptops.
                      all of them were robin brand.
                      iirc the ones we played with in their early days had acetone or methylene chloride in them at a partial vacuum.
                      • Pyr0Beast
                        • Feb 2009
                        • 406
                        Sorry for revival. I've had one before fail here and another one failed now.
                        Bah HP ...
                        Tried refilling it - changed only to worse.
                        • Victor Moreira Silva
                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                          by Victor Moreira Silva
                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                          Well, my decice specs are the following:
                          Model: Acer Nitro 5 AN517-54-55T5
                          CPU: Intel Core i5-11400H
                          GPU: NVIDIA GeForce GTX 1650
                          Motherboard: GH51G LA-L181P Rev:1c
                          The symptom:
                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                          05-26-2025, 10:49 AM
                        • CyTECH ELECTRONICS
                          HP Envy 15 amd a10 5700m overheating cpu 1-2 mins
                          by CyTECH ELECTRONICS
                          I am having trouble with an old HP envy 15 touch with amd a10 5700m cpu.It was with 3 repair shops already they could not fix the not turning on issue.I fixed their mess and fixed the original problem which was?.... of course a shorted cap on the cpu power rail. So now it's all working but the cpu overheats in about 1-2 minutes.
                          Repasted properly, the heatsink sits fine on it,the heat is going through the heat pipe and the voltage is around 1.3v to the CPU.
                          Pins and the socket are fine.
                          Does anyone have any ideas?
                          What else can it be ?
                          Can the CPU be dead...
                          03-07-2025, 03:05 AM
                        • fhulgzz
                          HP Omen 16 no display
                          by fhulgzz
                          Hi I need help, I hope someone can help me.
                          Model: Omen 16 B0080TX
                          Board Code: DA0G3KMBCG0 REV:G
                          I have a hard time diagnosing because there is no schematics/boardview available yet, if you have, please share.
                          ISSUE
                          • My personal laptop I used for my repairs. While in sleep mode it wont turn back on so I long press power button to turn "off" then press again to turn "on" and there the screen is black, no display
                          • Charger is working
                          • It has power, keyboard lights is on but CAPS LOCK light is not, looks like its
                          09-06-2023, 07:34 AM
                          Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                          The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                          Securing a good thermal interface between...
                          10-07-2024, 04:35 AM
                        • acedogblast
                          by acedogblast
                          11-02-2024, 05:13 PM
