Any luck with this? I seem to be having a similar issue with an Omen 17.3
HP Omen 16 no display
HP OMEN 16-b0075TX motherboard DA0G3KMBCG0 today its happening to me, Power ON, LED ON, Screen OFF (Black)
all possible tricks from Internet are not working, from HP -> go to nearest Service Center !
How to fix it ? any ideas ?
ThnxComment
hi same also with me, btw have you tried to connect in monitor using hdmi? no keyboard light? or caps lock light? thank youComment
Both screens, either LCD or via HDMI are BLACK with no signs of light.
Keyboard is working, fans are spinning.
I tried to disconnect battery, pressed Power button for 1 min, swap RAMs, restart it, and nothing.
Anybody knows, where I can buy NEW motherboard ?
Hi I manage to solve this issue. After testing all the voltage found out its all normal.
It wasn't a bios problem also because I tried so many versions, even my back-up doesn't work.
So i have a hunch that it maybe a cold solder.
So I reball/resolder the 1.8v regulator since this is the one overheating. I also refresh the solder of the legs of the SIO and that is all. It works.
Dude, could you show on the diagram what exactly you soldered?Hi I manage to solve this issue. After testing all the voltage found out its all normal.
I have this model in my hands right now. Thank you for very much for clear photos of the motherboard with voltage markings, by the way. Currently, the computer charges but does not post. When pressing the power button, it lights up briefly, then goes off. The motherboard does not have any shorts I can find. The 5V Always rail is present. However, the 3.3V Always rail is not present. Under the infrared camera, the chip responsible for it is the only bright spot on the motherboard. I do get 3.3V on many pins of the EC chip. But, I think this voltage is generated by auxilary rails.
Because the schematics is not available for this model, could you help me identify the chip? It has "LE=BG" etched on it. Thank you.Comment
RT6258B - https://www.badcaps.net/forum/troubl...d-marked-le-8eI have this model in my hands right now. Thank you for very much for clear photos of the motherboard with voltage markings, by the way. Currently, the computer charges but does not post. When pressing the power button, it lights up briefly, then goes off. The motherboard does not have any shorts I can find. The 5V Always rail is present. However, the 3.3V Always rail is not present. Under the infrared camera, the chip responsible for it is the only bright spot on the motherboard. I do get 3.3V on many pins of the EC chip. But, I think this voltage is generated by auxilary rails.
https://www.badcaps.net/forum/troubl...19#post1482819Comment
If 3V regulator IC is heating up,always check resistance to GND on LDO pin.
5V ALW will be present on standby and 3v ALW will come up after power button on this platform.Comment
trepachka Hi Trepachka, I currently have an Omen DA0G3KMBCG0 with the same problem. It turns on briefly, then turns off. It only briefly turns on the 3V and then turns off. The 5V and 5VLDO are always on, and the 3VLDO are also on. It originally arrived with a short circuit in the external USB port. My question is, were you able to resolve the issue?.
I would greatly appreciate any help.Comment
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...09-06-2024, 09:30 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) schematic. Our...09-06-2024, 09:30 PM
This specification for the Acer Aspire Acer Aspire 3 A314-35 14 inch Laptop - (Intel Celeron N4500, 4GB, 128GB SSD, Full HD Display, Microsoft Office 365, Windows 10, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 3 A314-35 14 inch Laptop - (Intel Celeron N4500, 4GB, 128GB SSD, Full HD Display, Microsoft Office 365, Windows 10, Silver) boardview and Acer Aspire 3 A314-35 14 inch Laptop - (Intel Celeron N4500, 4GB, 128GB SSD, Full HD Display, Microsoft Office...09-07-2024, 01:00 AM
- Loading...
