A2159 820-01598-06, charging but not running from batt
  • willumpie82
    • Oct 2015
    • 13
    • Netherlands
    Hi All,
    I'm diagnosing a A2159 with the following issue
    After waterdamage the device won't run from battery, when USB-C is connected it runs fine, battery seems to be charged, battery state is readout correctly, but when charger gets disconnected the machine shuts off.
    I think it must have to do something with the circuit that combines the PPBUS_G3H and PPDCIN via the two diodes. In previous models this was done via a BAT30 SOT-323.
    I tried to locate the PP3V3_G3H regulator but can't find anything on the board that I can identify as such
    as many other people mentioned, unfortunately no schematics/brd available for this new device.
    any clues welcome :-D
    www.badcaps.net
  • willumpie82
    • Oct 2015
    • 13
    • Netherlands
    Re: A2159 820-01598-06, charging but not running from batt
    reply to self,
    I suspect the battery board to be toast, when I measure the pads with nothing connected I measure ~12v, when i connect it to the board it drops to about 3v
    I found the input circuit... found also that when I apply 12v @5A to the capacitor near the batt flex (with no batt connected) it runs from my fake battery
    (see my annotated image I uploaded)
    www.badcaps.net
    • MobileXT
      • Oct 2012
      • 196
      your battery is shot from the water damage
      • igeektech
        • Jul 2017
        • 18
        Did replacing the batt fix the issue?
        • flat-earther
          ASUS X54H laptop thinks it's always charging even with charger unplugged
          by flat-earther
          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
          Windows also shows ''Plugged in'' when charger is not connected.
          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
          If I let battery run out and say it has 3% Windows will...
          06-24-2025, 09:32 AM
        • Scoff
          HP Probook 470 G4 - Power and Charging Problem
          by Scoff
          Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
          Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
          07-03-2023, 09:28 AM
        • das96
          Inspiron motherboard (la-j091p) with 19v to batt connector, so battery is not charging
          by das96
          Hi, I have an Inspiron motherboard (la-j091p) with 19v to batt connector, so battery is not charging and power off when connect the battery. I think its resistor fault, anyone can help me sort this. Thanks in advance
          10-02-2024, 01:45 AM
        • SluggerB
          Help with trying to fix phone that is not charging (Pics inside)
          by SluggerB
          I have two TCL A30 phones.
          Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
          New Phone: Works fine, bought as a donor board to try and repair Old Phone
          My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
          08-12-2024, 08:11 AM
        • CPUFiddler
          Acer Nitro 5 AN515-45 not charging
          by CPUFiddler
          Hi there. I am trying to repair an Acer Nitro 5 AN515-45 and it's giving me some trouble. I have access to SMD rework station, variable power supply, digital oscilloscope, thermal camera, multimeter, stereo microscope.
          This laptop will boot and run from the power brick and/or the internal battery, but it will not charge the battery. NirSoft BattInfo tells me the charge/discharge currents, so I'm confident in saying that it's not charging. In addition, there's no increase in voltage at the battery connector when the laptop thinks it's charging, not even a few millivolts.
          I've downloaded...
          03-19-2025, 07:44 AM
