Alienware 17 R5. Does not recognise LCD...
  • Weelcup
    TopTech
    • Oct 2017
    • 302
    Hi friend.
    I have an alienware 17 R5 laptop. Which is providing LCD failure code. I have replaced the full screen unit to Full HD , QHD and 4k versions but same issue. It is just providing the LCD failure code.. which means an issue with the motherboard. It does have GTX1080 chip on board and i was wondering if the chip is causing the issue. Or might be the cpu built in intel graphic.. it is i9 cpu.
    I would be thankful if someone help me to identify the signal that is responsible for the checking the LCDfailure...
    I could not find the exact schematics of the board but this is close schematics version which belongs to 17 R4 ...
  • khaahk
    • Dec 2013
    • 786
    • Estonia
    Re: Alienware 17 R5. Does not recognise LCD...
    Pin 28 on edp connector might be the one. Goes to the pch.
    • Weelcup
      TopTech
      • Oct 2017
      • 302
      Thanks for the reply.
      I will check it.
      • Weelcup
        TopTech
        • Oct 2017
        • 302
        I will check it.
        Hi again
        I tried to trace the DET line but it is very hard to find it out. This because the PCH is different in the model i have . My PCH is SR40E and the one the schematic providing is SR2CE.
        However, when i connect the motherboard to external display it does not post too and provide the same error code.
        Very confusing!
        • khaahk
          • Dec 2013
          • 786
          • Estonia
          What is the voltage on pin 28 with screen attached and disconnected and machine powered on?
          What is resistance to gnd on pin 28 when screen attached and disconnected?
          As you have changed the whole screen assembly then i see two possibilites at first:
          1. There is no pullup for the line
          2. The pch has failed on that pin and is pulling the line low.
          Most likely screen should pull the pin to ground when screen is connected. The mainboard checks for lcd on boot and does not post if lcd not connected.
          Or some other unknown error which we can not think of...
          • Weelcup
            TopTech
            • Oct 2017
            • 302
            Hi
            Thanks for following up..
            Well pin 28 have 3.3v. Even when lcd is connected/not connected just after powring up.
            However, the +LCDVDD signal is missing. Which i think should be there before the lcd signal beck via DET.
            By following up. UV17 "LCD power controller" is not getting the enable signal. I mean the ENVDD is missing. Now the ENVDD is not shorted and the output is not shorted. So was trying to trace the ENVDD signal. But in the given schematics the ENVDD is privided by UV22 chip. UNFORTUNATELY, the board version that i have does not have such chip on board. I mean it is not in the board design. But when checking the enable pin on UV17 it gives 100k resitant to ground. Which is supposed to be so. Therfore, i was suspecting the pch. But not sure.
            I bought a bios dump online and flashed the bios but same issue. No LCDVDD.
              • 21218
              Look around the board for a similar chip to UV22,there must be a multiplexer chip somewhere.
              • Weelcup
                TopTech
                • Oct 2017
                • 302
                I was seeking for the chip but could not find such chip. Giving the fact that the LA-F552P (my board) has a different PCH chip which is SR40E (CoffeeLake). compared to LA-D753P which have KabyLake PCH SR30W ... so was wondering if it still needs multiplexer chip!
                However, there is a Signal IGPU_ENVDD in the schematics i uploaded which goes to QG506 ... i checked resistans between the ENVDD & IGPU_ENVDD and it is only 2ohms. And was thinking it to be combined in this version!
                All the chips you mentioned in the photo are available in the La-D753p too. But not providing the enable signal.
                • piernov
                  • Jan 2016
                  • 4437
                  • France
                  You have to measure +LCDVDD or ENVDD voltage while turning on the board. On some machines the voltage will fall back down if the display isn't recognized.
                  Sometimes the LCD power switch goes bad in a way that it's not fully shorted to ground but still cannot send out the correct voltage.
                  Also what's the history of the machine?
                  • Weelcup
                    TopTech
                    • Oct 2017
                    • 302
                    Thanks for the reply,
                    I did turn on the board with attached probe on measure the enable signal and the output signal of uv17.
                    There are not output whatsoever. After couple of seconds the enable signal recieve only 0.2V and the output becomes 0.3v ... and that is it.
                    I have replaces uv17 with new one. But same issue.
                    The board history as i knew, was 19v shorred to ground. The cause was a cap. And been replaced. Then i found another short in pu500 the cpu controller. Also replaced. And that is it. Now it gives the lcd failure error.
                    One more thing to mention. It seems that the graphic chip have a seperate bios controller. UG13.. i was wondering if it is any related to the enable signal.
                    • Weelcup
                      TopTech
                      • Oct 2017
                      • 302
                      Sorry in the above reply, i meant 0.2mV and 0.3mV respectively.
                      • khaahk
                        • Dec 2013
                        • 786
                        • Estonia
                        I would make one more measurement to rule out that the lcd connector has bad connection:
                        1. Try to measure if the lcd assembly has pin 28 connected to ground (measure only on display assembly, not connected to mainboard.)
                        If yes then maybe the edp connector on the mainboard has pin 28 broken?
                        If not then i would just for the purpose of testing solder a jumper wire from pin 28 to gnd to see if pulling lcd detect signal low would make a difference.
                        I am assuming that the schematics is correct on the edp connector, otherwise might be bad idea.
                        • Weelcup
                          TopTech
                          • Oct 2017
                          • 302
                          I believe so. I mean pin 28 is the same as in the schematics.
                          I was not about this. And was wounder if it is safe to ground pin 28. Is that how the pch detect the lcd?
                          Just a bit worried to do so.
                          • khaahk
                            • Dec 2013
                            • 786
                            • Estonia
                            If the pinout of edp is correct then there should be no problem.
                            Did you measure the pin 28 resistance to gnd on the lcd assembly?
                            • Weelcup
                              TopTech
                              • Oct 2017
                              • 302
                              Well, on the lcd assembly (disconnected from the motherboard) there is no measure . I mean the multimetre shows OL. Just like a seperated line.
                              The resistance to the ground, however, for pin 28 on the motherboard is 12.6k...
                              • khaahk
                                • Dec 2013
                                • 786
                                • Estonia
                                So we have to assume that lcd det signal is not used on that model and forget about pin 28.
                                • Weelcup
                                  TopTech
                                  • Oct 2017
                                  • 302
                                  I see..
                                  I have checked the LCD_TEST signal. It flacuate between 0 and 1v while the lcd is disconnected and the board is connected to power source but not powered on. Then when i power it on (with the lcd disconnected) the LCD_TEST signal vanishs.
                                  One more thing i noticed is that the pin 36 INV_PWM signal is not provided but the pin is not shorted.
                                  So now ... the +LCDVDD and INV_PWM are both missing. Both provided fron UV22 in the schematics but my board does not have such chip.
                                  • piernov
                                    • Jan 2016
                                    • 4437
                                    • France
                                    DET is probably eDP HPD signal which the panel should pull high after turning on. (obviously require the panel to get 3.3V at least for a short amount of time)
                                    EDIT: sorry my bad, looked at the schematics and there is another line for EDP_HPD. So what I'm saying applies to EDP_HPD not DET.
                                    • Weelcup
                                      TopTech
                                      • Oct 2017
                                      • 302
                                      Aha!
                                      i will trace that signal and see...
                                      by the way, DET signal is 3.3v on la-d753p board but not in mine...
                                      thanks
                                      • khaahk
                                        • Dec 2013
                                        • 786
                                        • Estonia
                                        There are ton of topics regarding alienware machines with nvidia gpu-s and w10 making lcd-s not working. The topics indicate that the edid information stored in panels get corrupted and then follows the LCD not detected error.
                                        But if you have tried working screen then that should not be the case.
                                        Check EDP data lines in diode mode to see if they measure the same.
                                        • Simone Vergani
                                          Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                                          by Simone Vergani
                                          I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                                          To assist with troubleshooting, I'm attaching two power circuit schematics:
                                          • Power
                                          03-05-2025, 02:25 PM
                                        • abajor
                                          Alienware Area-51 R2 Boot Loop issue.
                                          by abajor
                                          I have the above mentioned Alien Ware A51 R2, currently it randomly will boot into the OS but more often than not it boot loops, I'm assuming there's an issue with power regulation somewhere.
                                          It comes with Dual 180 Watt Dell PSU, which is ironic since the thing claims it requires 420 watts in the bios screen.
                                          To rule out the power bricks I've attempted to power up the Laptop with a 330W and 240W Dell PSU at the same time, it still has the same boot loop issue so the problem is definitely the laptop.
                                          Right now I'm trying to dig through the PDF schematics and Board...
                                          03-08-2024, 10:08 PM
                                        • armands0212@gmail.com
                                          Alienware 15 r2 error 4 beeps code.ram issue
                                          by armands0212@gmail.com
                                          Hi all.i have problem with my alienware 15 r2.basically its keep beeping 4 times at startup-what means there is ram issue.i already tried 10 different ram sticks with different speeds and voltages but nothing helps.tried to flash bios to see if that will help-but no luck.
                                          Ram sockets looks fine as well,cleaned them and carefully inspected
                                          So maybe someone had this problem as well with any of dell laptops and have some ideas what else i can do?
                                          05-23-2023, 12:48 PM
                                        • Bupi452
                                          Alienware m15 r5 Ryzen 9 5900hx RTX 3070 MB-DC in connector issue
                                          by Bupi452
                                          Hi, everybody
                                          Yesterday I was about to re-paste my laptop, when during the disassembly I noticed that the DC cable from DC plug to the mainboard looked discolored​ and after a bit of prying I found out why...
                                          I am looking for the socket on the mainboard does anyone have an idea where I could get one? I have already looked in the board drawing and found out the manufacturer (ACES_50493-01301-P01) but it does not seem to be available for purchase...
                                          does anyone an idea where I could get one?
                                          PS
                                          The cable has a part number and can be bought on EBAY but I did not find...
                                          01-08-2025, 11:51 PM
                                        • Nikan.e
                                          Alienware 13 R3 repair - power issue or bad super-IO?
                                          by Nikan.e
                                          Greetings and Salutations!
                                          I have BAP00 board in front of me, which does not want to turn on. Nothing except for the AC power is connected.
                                          +3VLP - present
                                          RTC power - present // no battery connected
                                          * +3VALW - present
                                          * +5VALW - present
                                          * +LAN_IO - 0.00V
                                          * +3V_PCH - 0.05V
                                          * +1VALW - 0.00V
                                          * +1V_PCH_PRIM - 0.00V // same rail as +1VALW
                                          Note : ON* means that this power plane is ON only with AC power available, otherwise it is OFF
                                          +1VALW - 47Ohms
                                          +3V_PCH - MOhm range
                                          +LAN_IO - 100KOhm...
                                          11-07-2024, 03:51 PM
