Alternative Mosfet
  • grendal10
    • Apr 2015
    • 25
    Alternative Mosfet
    hi
    im trying to fiix a hp pavillion, ive found 2 shorted mosfets.Unfortunatly they have been discontinued, im trying to find an alternative but finding that most i have looked at have a lower maximum Continuous Drain Current (ta lower tc higher) would this be ok or not and wondered if anybody knew of a better alternative.im trying to replace AON6370
    best replacment found so far is NVMFS4C310N.On the datasheets what do i need to make sure match on the replacement mosfet?
    thanks in advance for any info given
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Alternative Mosfet
    Write board model number, attach schematics and point out which components you are talking about.
    • jasko_jacker
      • Oct 2014
      • 1140
      • italy
      the important parameters are:
      VDS and VGS which should be the same
      Rds (on) which should be equal to or less
      Id (continuos drain current) and Idm (pulsed ..) which can be greater but not less
      This is the direct answer to the question, but as Piernov says, it should be understood why the mosfets burned, if there is a short somewhere ....
      • grendal10
        • Apr 2015
        • 25
        Thanks for the replies, unfortunately i can't find a schematic, i bought the laptop liquid damaged which was what im guessing caused the mosfet to blow, since the mosfets have been removed the shorts on the board have gone.Didn't want put an incompatible mosfet on and blow something else
        • piernov
          • Jan 2016
          • 4439
          • France
          MOSFET requirements are not the same depending on the circuit so that's why I asked what I asked.
          • goodvibes
            • Apr 2020
            • 11
            Thank you, @piernov for asking this question! I'm working on an ASUS board with the similar problem of a blown, discontinued MOSFET and trying to find a suitable replacement. Thanks @jasko_jasker for those parameters!
            • Jane
              How do you test MOSFET in laptops ?
              by Jane
              I tried to use this method:
              Testing an N-channel MOSFET:
              Step 1: Discharge the Gate (turn off the MOSFET)
              Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
              Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
              Step 2: Charge the Gate (turn on the MOSFET)
              Now, place the red probe on the Gate (G) and the black probe on the
              09-27-2024, 03:31 AM
            • Nooy
              VGA MOSfet permanently shorted and loss of MOSfet pad
              by Nooy
              Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
              I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
              02-14-2024, 02:26 AM
            • redbaron1007
              Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
              by redbaron1007
              I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
              Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
              09-09-2025, 11:10 AM
            • AppleLover123
              Asus X712EA 3 volts after the first mosfet
              by AppleLover123
              Hey guys,
              i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
              I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
              Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
              I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
              Now i thought something...
              12-15-2024, 07:49 AM
            • MicroSMD Lab
              by MicroSMD Lab
              I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
              01-10-2024, 06:36 AM
