LENOVO G50 -70 power on No screen
  • ghost73
    • Feb 2020
    • 28
    • GREECE
    Re: LENOVO G50 -70 power on No screen
    Originally posted by lapfix
    3Vs appear after switshing power button ,this is your S0 satate.It supply many others IC's .
    why you don't have it on pin 20/23 !!
    can you take the measue of Q24 ( D/G/S) and see like Kiraro says if thers is a short on it !
    In the Q24 i have .... the 17.6 v is OK ???
    • lapfix
      • Mar 2020
      • 2733
      • my workshop
      Nice Q24 is OK ,you have 17.6v on gate because it's N-channel , the gate must be equal or higher than the voltage on Drain .
      I really don't understand what you make! do you have 3V on pin 23 and no voltage on pin 20!
      • ghost73
        • Feb 2020
        • 28
        • GREECE
        yes .. i have 3v on pin 23 but in pin 20 no ... (now i have with the bringe)
        • lapfix
          • Mar 2020
          • 2733
          • my workshop
          Something is wrong/not clear !
          first what do you mean by : I put a ligth in screen and i see activite .!
          second at jedp connecter we have :
          pin 1/2 = 20v
          pin 21/22 = 3.3v
          pin 20 = 0v
          pin 23 = 3v
          can you complete the measurements for : pin 14/16 /19 /30
          UE1:
          Pin 81 = ENBKL
          Pin 22 =PLT_RST
          JDDR1 :
          Pin 30 =CPU_DRAMRST
          JPWRB1:
          Pin4 = LID_SW
          PL9=CPU_CORE
          • ghost73
            • Feb 2020
            • 28
            • GREECE
            pin 1/2 = 20v
            pin 21/22 = 3.3v
            pin 20 = 0v
            pin 23 = 3v
            UE1:
            Pin 81 = ENBKL
            Pin 22 =PLT_RST
            JDDR1 :
            Pin 30 =CPU_DRAMRST
            JPWRB1:
            Pin4 = LID_SW
            PL9=CPU_CORE
            I try to take a picture ...to see what i mean
            pin 30 = 3.4 v
            pin 14 = 0
            pin 16 = 0
            pin 19 = 0
            • lapfix
              • Mar 2020
              • 2733
              • my workshop
              #26
              i m waiting for the other mesearments that i'm saking for !!
              • ghost73
                • Feb 2020
                • 28
                • GREECE
                #27
                UE1:
                Pin 81 = ENBKL = 50Ω
                Pin 22 =PLT_RST = 3.4 V
                JDDR1 :
                Pin 30 =CPU_DRAMRST = 0V
                JPWRB1:
                Pin4 = LID_SW : 6.6 V
                PL9=CPU_CORE
                • ghost73
                  • Feb 2020
                  • 28
                  • GREECE
                  #28
                  This line blink in the screen
                  • lapfix
                    • Mar 2020
                    • 2733
                    • my workshop
                    #29
                    Ghost , take again the measures , in voltage please !
                    Pin4 = LID_SW : 6.6 V..are you sure !!
                    DRAMRST must be 1.35v ,without it no display.
                    Since you are getting PLt_RSt means almost everything is ok in power sequence.
                    there's a a resistance and capacitor between CPU and Pin 30 (JDDR) , what's the voltage for both side of RC22, and is CC1 short to ground.
                    Make sure your problem NOT on LVDS cable or LED panel. Make sure you're using known good DDR3L
                    At last flash a known good bios ,it is very likely to solve your problem.
                    • ghost73
                      • Feb 2020
                      • 28
                      • GREECE
                      #30
                      Sorry
                      Pin 81 = ENBKL = 0V I try to test it again
                      I found the RC22 and i send you the measures.
                      i dont have programmer
                      I have 2 cable for LVDS ,, and two panel i am sure about this ...
                      The DDR3L test OK ..
                      • ghost73
                        • Feb 2020
                        • 28
                        • GREECE
                        #31
                        well
                        i take new measures .. In JDDR1 the number is 2-4-6
                        the last measures is wrong
                        This is correct
                        JDDR1 30 = 1.37 V
                        in the image u see the RC22 and CC1 .
                        • Mgiffune
                          by Mgiffune
                          06-09-2024, 10:28 AM
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • Mita99
                          Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                          by Mita99
                          Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                          Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                          Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                          04-27-2025, 07:20 PM
                        • Dr.d
                          Help please..Lenovo ideapad 5 14itl05 power and charging problem
                          by Dr.d
                          I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                          Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                          04-05-2024, 11:48 AM
                        • grimacelord
                          HP 15-EH1070wm - Black Screen With Power LED.
                          by grimacelord
                          I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
                          First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
                          01-28-2023, 10:50 AM
