Dell Inspiron 3521 [La-9104p] no power
  • classicandy
    • Apr 2018
    • 308
    • Nigeria
    Hello, Please I have this Dell Inspiron 3521 [La-9104p] that is dead. There is no visible damaged component. It just tripped off while booting one certain day and has not powered on since then. Doesn't charge either.
    I have replaced PU200 [3.3V/5V IC]
    Currently, when I connect the charger;
    B++ is present
    3.3VALWP/5VALWP not present
    VREG3 and VREG5 is present
    PGOOD is not present
    RTC is ok.
    Where else do I need to check to determine the fault?
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: Dell inspiron 3521 la-9104p dead
    it's better you open a new Thread if you could, for 3/5VALWP you need Enable from SIO voltage on pin 6 20 on PU100 and you need +PWR SRC to PQ100 PQ101 & what is the resistance PL102 PL101 ?
    • piernov
      • Jan 2016
      • 4435
      • France
      Re: Dell Inspiron 3521 [La-9104p] no power
      Moved to a new thread for a different problem. (originally posted in https://www.badcaps.net/forum/showthread.php?t=63872 )
      • kiraro
        • Jan 2016
        • 177
        • North NY
        What about :
        UE1:
        -Pin 111, EC_VDD0 (3.3v)
        -Pin 110, ACIN
        -Pin 112, EC_ON
        -Pin 115, LID_SW#
        PQ201:
        -Pin1 voltage, check PR214(100k), VL(5v) present in one side of this resistance.
        -Pin2 voltage(EC_ON through PR213)? and check PR213(2.2k).
        • classicandy
          • Apr 2018
          • 308
          • Nigeria
          okay. Thanks.
          By +PWR SRC, I guess you mean B+. PQ100 and PQ101 have B+
          No PL102. I think you meant PQ102. I can't get any resistance on PQ102 or PL101.
          No voltage on Pin 6 and 20 of PU100 [Even on known good board]
          • classicandy
            • Apr 2018
            • 308
            • Nigeria
            • classicandy
              • Apr 2018
              • 308
              • Nigeria
              Originally posted by kiraro
              What about :
              UE1:
              -Pin 110, ACIN
              -Pin 112, EC_ON
              -Pin 115, LID_SW#
              PQ201:
              Thanks. Here are my readings:
              UE1:
              Pin 111 = 3.36v
              Pin 110 = 3.0v
              Pin 112 = 3.36v
              Pin 115 = 0v
              PQ201:
              Pin 1 = 0v
              Pin 2 = 3.36v
              PR214 = 56K ohms
              - Pin 1 = 0v
              - Pin 2 = 5v
              PR213 = 2.1K ohms
              - Pin 1 & 2 = 3.36v
              • kiraro
                • Jan 2016
                • 177
                • North NY
                what voltage you get on ENTRIP1 ( pin1 of pu200) and ENTRIP2 (pin6 of pu200)?
                • lapfix
                  • Mar 2020
                  • 2584
                  • my workshop
                  Without the voltage on pins 1 and 6 the chip is being told to "turn off "the outputs though.
                  So measure the voltage on pins : 1.6.13.
                  What about ps_id pin 16 on UE1
                  • classicandy
                    • Apr 2018
                    • 308
                    • Nigeria
                    Pin 1 = 1.36v
                    Pin 6 = 1.36v
                    compared with a working board, its similar
                    • classicandy
                      • Apr 2018
                      • 308
                      • Nigeria
                      Pin 1 = 1.36v
                      Pin 6 = 1.36v
                      Pin 13 = 3.6v
                      PS_ID:
                      3.3v not present, straight from PJPDC [DC IN] Pin 1 to Pin 16 of UE1.
                      +5VALW and +3VALW needs to be present for PS_ID to have 3.3v
                      • lapfix
                        • Mar 2020
                        • 2584
                        • my workshop
                        with the PU200 voltages requirements that you got at pins : 1.6.8.13.16.17...and you don't have the outputs at pins :11.20 , a bad chip or a short are still the most likely causes.
                        With diode mode measure VREG3, VREG5, PL200, and PL201 (that's pins 8, 17, 20, and 11) for shorts to ground.
                        NB : PS_ID it's not straight from PJPDC [DC IN] Pin 1 to Pin 16 of UE1, what's the voltage at PQ901 (Drain ,source and gate )
                        • classicandy
                          • Apr 2018
                          • 308
                          • Nigeria
                          Regarding PS_ID, what i meant was, I checked all the components connected in one way or the other on the PS_ID line, starting from Pin 1 of PJPDC down to Pin 16 of UE1.......
                          • classicandy
                            • Apr 2018
                            • 308
                            • Nigeria
                            no shorts to ground on VREG3, VREG5, PL200 and PL201 (PINS 8, 11, 17 & 20)
                            • classicandy
                              • Apr 2018
                              • 308
                              • Nigeria
                              But I noticed that the Charging IC (ISL88731C) gets warm a little. I did the Isopropyl test and compared it with a known good similar motherboard.
                              I've also compared voltages on the charging IC with charger plugged in (without battery), they seem to have the same readings.
                              What could be the cause and solution?
                              • Ikung
                                • Nov 2013
                                • 34
                                • Malaysia
                                Hi, can you measure again all pins on PU100 with battery connected?
                                • classicandy
                                  • Apr 2018
                                  • 308
                                  • Nigeria
                                  Here are the new readings with battery connected
                                  • Ikung
                                    • Nov 2013
                                    • 34
                                    • Malaysia
                                    ISL88731C does not function when VDDSMB is below its specified Under Voltage Lockout (UVLO) voltage. All of the SMBus registers in ISL88731C are powered by VDDSMB and are set to zero when it is below the UVLO threshold.
                                    Other functions are unpredictable when VDDSMB is below the UVLO threshold.
                                    • classicandy
                                      • Apr 2018
                                      • 308
                                      • Nigeria
                                      Thanks so far, I've attached the new readings for PU200.
                                      Note: In the image attached, the board I claimed to be "Good" Powers On and charges the battery normally. But isn't entirely good in general because it doesn't display. I'll start a new thread for that board as soon as i'm done with this current one.
                                      There's no short in PQ202, PQ204, PQ203 & PQ205
                                      • classicandy
                                        • Apr 2018
                                        • 308
                                        • Nigeria
                                        By VCC, did you mean VDDP_LDO? because, that's the only pin with 5v on PU100.
                                        Or probably, external 5v would more preferable.
                                          DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:36 PM
                                          DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:30 PM
                                          09-12-2024, 03:28 PM
                                          DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
