Toshiba Satellite L50-B-2G7 doesnt save BIOS Settings / reverts always to default
  • notorius
    • Mar 2020
    • 10
    Hey guys, im new here and i have a problem.
    I bought the above mentioned Laptop without a Harddrive.
    I put in a SSD and wanted to install Windows but i cant boot neither from
    USB-Stick nor from the build-in DVD-Drive.
    So i went into the BIOS and changed the boot sequence. But then, after
    saving the settings (+reboot) i checked BIOS again and still had the old default settings loaded.
    I also needed to have the CSM-Mode instead of UEFI for proper Installation, so i changed it , and guess what - after the "Save and Exit" the Notebook restarted and had UEFI again as default.
    So in other words, it doesnt matter which settings i change, after save+exit i will always get the default settings.
    The only thing which is saved correctly is the date + time. (which ist stored in the battery - which i found out already )
    Then i checked for a CMOS Jumper on the Mainboard (DABLIDMB8E0 REV E) and couldnt find anything beside Password reset - which i dont need, since User/Supervisor Passwords wont be saved anyway on that machine.
    After googling the problem i found out a Link, which could be the reason ( and describles the problem very well ):
    https://bugs.launchpad.net/ubuntu/+s...x/+bug/1734147
    So i'm kinda lost, what to do.
    Any Ideas ?
  • kodox
    • Jul 2017
    • 322
    • Indonesia
    Re: Toshiba Satellite L50-B-2G7 doesnt save BIOS Settings / reverts always to default
    had you try update the bios?
    from your link given, it discussed about bios and i think they updated the bios by "the linux" way which i'm not good at
    • notorius
      • Mar 2020
      • 10
      Apparently there is no way to use any Media to boot from.
      Tried UEFI / CSM bootable Sticks. Win8 DVD , Pre-Installed SSD with Windows 10.
      None of them are booting, the Screeen shows ( no bootable device please restart system )
      • kodox
        • Jul 2017
        • 322
        • Indonesia
        to boot from media using UEFI, partition type of the media had to GPT and i'm sure what you have in hand is MBR, so the UEFI bios consider that no bootable drive found
        • notorius
          • Mar 2020
          • 10
          Even on a original Win8 DVD ?
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            Even Win 10 can be in mbr partition scheme type flash drive or DVD, so just create Win 10 GPT partition scheme for UEFI usb drive with rufus, and you are good to go.
            >>>How To Create A Windows 10 UEFI Boot Media Using Rufus Tool<<<
            Become a Badcaps supporter
            Thanks to all supporters.​
            • notorius
              • Mar 2020
              • 10
              Done that. Didnt worked. Win10 on Rufus with GPT/UEFI
              I tried it with Quickboot (F12) and picked the USB-Stick directly -> no media found. restart the system.
              Problem is not the media, but the BIOS itself. Its kinda broken.
              • kodox
                • Jul 2017
                • 322
                • Indonesia
                tried another usb port?
                • notorius
                  • Mar 2020
                  • 10
                  sure, tried ofc all of em.
                  • kodox
                    • Jul 2017
                    • 322
                    • Indonesia
                    you should try the "hard way" to update the bios then...
                    • notorius
                      • Mar 2020
                      • 10
                      that means ?
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3590
                        • slovakia
                        dont u have older linux like ubuntu on it?
                        ubuntu 17.10 have bug that leaves BIOS in uefi locked state just like yours
                        u need to reflash bios
                        here u have just yours bug
                        https://www.youtube.com/watch?v=iiFHhEqluCY
                        • kodox
                          • Jul 2017
                          • 322
                          • Indonesia
                          that means ?
                          remove the bios chip from mainboard and flash it using programmer
                          • notorius
                            • Mar 2020
                            • 10
                            Originally posted by ktmmotocross
                            thanks man. A good Link.
                            • Conste
                              Clevo W25CEW doesn't save Bios settings / shutdown issue
                              by Conste
                              Hello together,
                              I have a Clevo W25CEW (Terra 1541) with some strange symptoms:
                              1. I cannot save Bios settings by pressing "save settings" in the bios. By pressing "save & exit" it will save the settings.
                              2. I can boot normally (UEFI installation), but when I shut the machine down and start it after a few seconds again it will show resume from hibernation and shutdown after POST, just before windows would boot. Then it will go back to factory settings and my UEFI installation will not boot!
                              Already changed the CMOS battery...
                              09-01-2021, 10:34 AM
                            • YG007
                              Asus BIOS How To Reset To Default Settings?
                              by YG007
                              Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
                              I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
                              06-05-2023, 08:22 PM
                            • throwaway327
                              by throwaway327
                              Model No: RC72LA
                              Serial No: SBNVKD001014459
                              06-18-2025, 05:52 PM
                            • AquaMan Ua
                              by AquaMan Ua
                              05-17-2025, 09:40 AM
                            • Wg188
                              ACER Veriton Z4660G AIO bios help
                              by Wg188
                              I have an Acer veriton Z4660G all in one pc,
                              Model: Z4660G-I5850H1 (VZ4660G_W)
                              Need bios dump and schematic would save my life !
                              to make a long story short I bought this all in one used
                              with a broken lcd, with the objective of making a custom desktop out of it
                              ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                              06-17-2023, 02:20 PM
