Lenovo G50-70 switch on problem
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need help on this LENOVO G50-70 ACLU1/ACLU2 NA -A271 laptop.the problem is turning on then goes off unless you steady the probe to pin 3 and 4 of the power button. here is the voltages on of PINS ON JPWRB1
    PIN1 +3VL =3.3V
    PIN2 NOVO_BTN# = 3.3V
    PIN3 ON/OFFBTN# = 0.94V ONLY
    PIN 4 LID_SW# = 3.3V
    PIN 5 AND PIN6 = GROUND
    I check on kbc ON pin 110 PWRSW# =3.3v and resistors connected =3.3v
    ANYONE can help me on this please
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Lenovo G50-70 switch on problem
    what is the voltage on R114 both ? is R114 100K ?
    • String2016
      • Nov 2015
      • 2238
      • philippines
      cannot find where is r114 located does this resistor connected to kbc pin110?
      • String2016
        • Nov 2015
        • 2238
        • philippines
        could you show where is the R114 Located nearby?i cannot find on the board i check there is no boardview for this unit
          • 21849
          check D15 ,diode measurement
          • Techtiger
            • Oct 2014
            • 1602
            • france
            check out the Pic
            • String2016
              • Nov 2015
              • 2238
              • philippines
              @smdflea d15 open line
              • String2016
                • Nov 2015
                • 2238
                • philippines
                @techtiger on pin4 connected to that is 3.4v and on the other side one is marked 0 and the other no component on it
                • Techtiger
                  • Oct 2014
                  • 1602
                  • france
                  ok then pin 3 should connect to this point , uplode a closeup pic near pin 110 SIO
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3627
                    • slovakia
                    did u check continuity of that 0 ohm resistor?
                    what u mean d15 open line. it is diode. in one direction open line and in other direction cca 600ohm
                    • String2016
                      • Nov 2015
                      • 2238
                      • philippines
                      @techtiger here it is the kbc pin 110 and the resistor connected pin110 directly connected to pin 3 on switch both resistor near pin110 have 10k resistance
                      • String2016
                        • Nov 2015
                        • 2238
                        • philippines
                        @ktmmotocross D15 no component ill measured on diode mode it show nothing and when i measured in ohms it shows 13.96k then goes to nothing
                        • String2016
                          • Nov 2015
                          • 2238
                          • philippines
                          any help on this please
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Voltage on PIN86 of KBC-without pressing power button/after pressing power button??
                            • ravi_1617
                              YY Solutions
                              • Jan 2012
                              • 348
                              • India
                              just a simple question will a NM-A272 shifting IO chip (IT8586E )will work on NM A271 ,I don't have a any IO chip programmer.
                              NM A271 IO chip is has heating problem
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                @ravi_1617, there are high chances it will work as the firmware of kbc seems same on both motherboard's
                                • ravi_1617
                                  YY Solutions
                                  • Jan 2012
                                  • 348
                                  • India
                                  Already swapped. 3.3 & 5 volts present. 3.3 volt at switch also present ,but board not starting, flashed bios too.
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Check ECRST and RSMRST present or not??
                                    • ravi_1617
                                      YY Solutions
                                      • Jan 2012
                                      • 348
                                      • India
                                      ECRST not present .RSMST unable o locate any where. i tough of checking with battery power, than found BATT+ showing (20 volts)
                                      • ravi_1617
                                        YY Solutions
                                        • Jan 2012
                                        • 348
                                        • India
                                        Battery is not charging ,
                                        PQ303 power Present at Source and Gate
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                        • s_specialist
                                          Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
                                          by s_specialist
                                          Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
                                          07-07-2025, 11:47 AM
                                        • perzyk23
                                          Lenovo T580 - LCD Panel problem - error 0288
                                          by perzyk23
                                          Good morning,
                                          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                          10-25-2024, 12:42 AM
                                        • c.daniel
                                          Lenovo V310-15IKB weird bios problem...
                                          by c.daniel
                                          Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
                                          sn LR09493E
                                          MB DAOLV6MB6F0 REV. F
                                          The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
                                          Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
                                          Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
                                          08-22-2025, 05:39 AM
