no 3v and 5v section voltage reading
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Hi my board is HUSK MB 11309-248.4TU05.021
    The board is plugg and consuming 13 milliamp
    measuring the 3v coil no reading and the 5v coil no reading
    Ive measure the pins in PU4103 ( RT8223M)
    1- NO READING
    2- NO READING
    3- 4.4V
    4-NO READING
    5- NO RADING
    6- NO RADING
    7-3.3V
    8- 5V
    9-19V
    10- NO RADING
    11-3.3V
    12- 3V
    13-
    14
    15
    16-4.4V
    17-3.3V
    18- NO READ
    19-5V
    20- NO READING
    21-2V
    22-2V
    23-NO READING
    24- 5V
    i really need how to identify if the PU4103 is faulty or not
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: no 3v and 5v section voltage reading
    Double check your pin numbering, it doesn't match with the datasheet.
    • kalilinux25
      • Mar 2018
      • 2093
      • ZAMBOANGA SIBUGAY
      sorry
      1- 5V
      2- NO READING
      3- 2V
      4- 2V
      5- NO READING
      6- 5V
      7- NO READING
      8- 3.3V
      9- 4.4V
      10- NO READING
      11-
      12
      13
      14-3V
      15-3.3V
      16- 19V
      17-5V
      18-3.3V
      19- NO READING
      20-
      21
      22-4.4V
      23-
      24-
      ALL BLANK ARE NO READINGS
      SORRY I didnt notice
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Your readings are still wong as you have not counted pins correctly. PIN8 is VREG3-so should be 3.3V and PIN17 is VREG5-so should be 5V. You mentioned pin8 at 5V and pin17 at 3.3V which is impossible if you counted pins correctly. Look for the dot mark on your IC. Thats pin1. Look for datasheet and try to understand how pins are counted.@Kalilinux25, i dont want to be harsh but you have 289 posts to your credit and you still dont know how to count pins correctly-That's not a good sign. You need to invest in basic knowledge first.
        • kalilinux25
          • Mar 2018
          • 2093
          • ZAMBOANGA SIBUGAY
          ive reply for the new reading sir
          • kalilinux25
            • Mar 2018
            • 2093
            • ZAMBOANGA SIBUGAY
            sorry
            1- 5V
            2- NO READING
            3- 2V
            4- 2V
            5- NO READING
            6- 5V
            7- NO READING
            8- 3.3V
            9- 4.4V
            10- NO READING
            11-
            12
            13
            14-3V
            15-3.3V
            16- 19V
            17-5V
            18-3.3V
            19- NO READING
            20-
            21
            22-4.4V
            23-
            24-
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              I dont know how you take readings but i'm surprised by your readings:
              01. PIN15-its GND. You mention its 3.3V
              02.PIN1-Entrip1-Voltage should be 1.0-1.5V approx. Impossible to have 5V there. Same for pin6 as ENTRIP2.
              Infact i didnt read carefully all your pin readings as it doesnt make any sense.
              • kalilinux25
                • Mar 2018
                • 2093
                • ZAMBOANGA SIBUGAY
                Ive read again the pin 1 it is 5v reading
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3630
                  • slovakia
                  Leave ENTRIP1 floating or drive it above 4.5V to shut down channel 1.
                  https://cdn.badcaps-static.com/pdfs/...b196680b71.pdf
                  • abajor
                    A2141 PP3v3_G3H_RTC_X Diode Reading .104V Voltage 3.39V
                    by abajor
                    Have an A2141 which is reading about 5.2V 0.07A on all USB jacks, started doing the measurements.
                    PPBUS_3GH diode: measures good .45V
                    PPBUS_3GH Voltage: maybe not so good 12.25V maybe bad T2? Unit did not come up in DFU on configurator.
                    The weird so far is
                    PP3v3_G3H_RTC_X diode: .104V (WTF?)
                    PP3v3_G3H_RTC_X voltage: 3.39V (Normal)
                    Stopped there attempted reverse voltage injection at PP3v3_G3H_RTC_X with 1V. Instead of the circuit sinking any current, My PSU suddenly reads 3.4V with no current draw.
                    Not sure what any of this means...
                    03-18-2025, 10:27 PM
                  • stingerchamp
                    Ddr3/ddr4 ram section voltage requirements(working)
                    by stingerchamp
                    Follow this guide to verify voltage at RAM SECTION
                    DDR 3 ram section voltage check list at ram slot
                    DDR3 operating voltage VDD (at coil )= 1.5V PINs 75,76 ram slot
                    VRef_DQ = 0.75 V at PIN 1
                    VTT/Termination voltage= 0.75V PINs 203,204
                    VRef_CA. = 0.75V PIN 126
                    VDD SPD = 3.3V PIN 199
                    SDA data = 3.3V PIN 200
                    SCL clock = 3.3V PIN 202
                    DRAM_RST# = 1.5V PIN 30
                    DDR 3L ram section voltage check list at ram slot
                    DDR3L...
                    12-12-2020, 02:07 AM
                  • alro7779
                    MOSFET? Is its voltage reading normal?
                    by alro7779
                    Hello, guys!
                    Got this 8-pin MOSFET (I presume) on the motherboard that I'm still trying to repair (HP Stream 11-ah117wm DAY0HGMB6C1 REV:C), close to the DC IN connector, and when I read voltage on Drain (5-8 pins) and Source (1-3 pins), I got the 19.81 VDC of the DC IN on each, but on the Gate (pin 4) it's 25 VDC. Is it normal? Now, I'm not quite sure the component is a MOSFET, but it looks like, and since it has the printed code on it totally unreadable, I can't try to find the datasheet. Can anyone give me a hand on this? Or maybe ff there's some MOSFET tutorial or something that you can...
                    06-19-2025, 08:19 AM
                  • Instafixx
                    Macbook A2179 820-01958
                    by Instafixx
                    Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                    The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                    I checked the Power Sequences below and found this -
                    Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                    PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                    PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                    05-20-2023, 05:19 AM
