Aclu3/aclu4 only charge battery when is off
  • maurovalero
    • Sep 2018
    • 69
    • colombia
    Forum this lenovo just charge when is off and when the battery is nearly 50% laptop shut down
    Any idea how start the revisión thx
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Aclu3/aclu4 only charge battery when is off
    Try another battery, make sure the correct AC adapter is used.
    • maurovalero
      • Sep 2018
      • 69
      • colombia
      Battery isnt the problem and adp is ok
      • maurovalero
        • Sep 2018
        • 69
        • colombia
        Adicionally the laptop just turn on whit battery dont whit adp, is the second time that i have this kind of problem
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          The laptop should turn on without battery and only on ac adapter. Measure voltage on first 2 dc-in mosfets(without battery connected and only on ac adapter). You need to measure PIN 1/4/5 for both mosfets.
          • techfreak9356
            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
            by techfreak9356
            09-14-2023, 11:10 PM
          • razenxd
            How can I charge that battery pack?
            by razenxd
            it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
            At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
            Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
            Now, I have noticed a few things.
            The "dead" battery, while connected to charger and NOT Charging will...
            12-05-2024, 06:11 AM
          • ruletero
            Acer a515-43 low battery charge voltage
            by ruletero
            Hi
            Acer A515-43
            LA-H801P
            Fail: Does not charge battery, has low voltaje on connector.
            Laptop didn't want to turn on, only charge led blinked.
            I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
            I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
            Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
            10-24-2022, 02:31 PM
          • Klevjetack
            Charge a L19D3PDA battery externally from the laptop
            by Klevjetack
            Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
            03-05-2024, 07:26 AM
          • dclass-pro
            Latitude 3301 not charge battery
            by dclass-pro
            Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
            I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
            I noticed 2 things:
            1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
            2) if I try to turn it on without the battery...
            05-06-2025, 06:19 AM
