HP ProBook 4510s low voltage battery
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    From AliExpress I bought battery described as replacement for HP HSTNN-IB89 which is 14.4V
    What eventually arrived is marked HSTNN-1B1D, 10.8V
    Contacted vendor who said “Our battery is 10.8V ,you can install it to see if charge”
    Advised vendor that I was unwilling to risk damaging notebook by using battery 75% of required voltage
    After opening dispute with AliExpress, vendor subsequently said “we have checked it,they are compatible you can used it”
    Should I believe vendor, or is there downside(s) to trying lower voltage battery?
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP ProBook 4510s low voltage battery
    Perhaps your aliexpress battery has lower cell counts then the original one. Should work but eventually you will have lower backup hours.
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      Thanks mcplslg123
      I've now fitted the battery, which worked fine and charged up without issue
      FWIW, this is the second Jigu branded battery I've bought
      Other was for a VAIO VGN-FW41E, where it's still going well after ~25 days
      Unlike HSW one from Aliexpress' Sunway Electronic Store which died before 10 recharges in same ProBook 4510s
      Contacted latter vendor who asked questions about how battery was treated, then stopped communicating after being unable to elicit any proof of abuse
      Jigu ones came in branded boxes with English and Cyrillic writing - HSW in a plain brown box showing how much pride its manufacturer has in their product
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        @pfrcom, I was sure it will work but you need to observe the backup time you get from fully charged replacement battery compared to the original one. I beleive you will get almost 25% less backup hours.
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          Went to use ProBook after unused overnight for ~12 hours
          Noticed orange charge light flickering, even though charger not plugged in
          Sinking feeling, pressed power button, nothing
          Notebook started with charger connected, but Windows 10 battery icon said 255% charged
          Dual-boot MX Linux showed a question mark on its battery icon, right click wouldn't show any status
          So:
          1. Is this ProBook 4510s a battery killer?
          2. Does HP somehow intentionally manage to stuff-up anything other than a genuine battery?
          • piernov
            • Jan 2016
            • 4439
            • France
            Market is filled with garbage batteries. I had 2 bad ones for a 4710s in a row, and happened for other laptops and for other people too.
            • jasko_jacker
              • Oct 2014
              • 1140
              • italy
              I discovered this application:
              PassMark BatteryMon,
              try to use it to understand the battery status
              • pfrcom
                Oldbie
                • Jun 2006
                • 1230
                Battery's controller seems to have had a fundamental failure (message after clicking BatteryMon Start)
                • pfrcom
                  Oldbie
                  • Jun 2006
                  • 1230
                  For comparison, here's what BatteryMon showed when I refitted the HSW battery which died before 10 recharges
                  • pfrcom
                    Oldbie
                    • Jun 2006
                    • 1230
                    Have now opened another dispute on AliExpress with vendor Top Laptop battery Electronic Technology co., LTD
                    Their first response – couldn't be more shifty
                    “Dear friend, I guess you bought wrong battery ,our battery voltage is 10.8V ,but your old battery is 14.4V .In fact, the voltage 10.8V and 14.4V is incompatible.And we did not sent wrong model ,and our battery same as description ,here is your correct battery link: https://www.aliexpress.com/item/1836...4b407056iYxtqW we can give you 10% discount to buy new battery ,and you can sell that wrong model to make money ,thank you .”
                    In contrast to their previous messages
                    and
                    you can used it”
                    Vendor's lack of ethics illustrated by their suggestion to sell the dodgy battery they've already supplied, and misrepresented
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • ruletero
                      Acer a515-43 low battery charge voltage
                      by ruletero
                      Hi
                      Acer A515-43
                      LA-H801P
                      Fail: Does not charge battery, has low voltaje on connector.
                      Laptop didn't want to turn on, only charge led blinked.
                      I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                      I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                      Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                      10-24-2022, 02:31 PM
                    • questore
                      XPS 13 9370 CMOS battery voltage always low
                      by questore
                      Hi Everyone,
                      I have brought you a mistery item
                      This laptop have come with some strange faults.
                      1. CMOS battery was flat 0v
                      Symptoms:
                      - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
                      Amp drawing was stuck at 0.005 milliamps.
                      - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
                      After inverstigation RTCD1 diode had a low value...
                      09-30-2025, 05:47 AM
                    • someonenotyou
                      HP ProBook 445 G7 no POST only on battery
                      by someonenotyou
                      Hi.
                      I have a strange problem with HP ProBook 445 G7 (DA0X9MMB8F0 RevF), that there is no POST while only on battery. The Caps Lock blinks 5 times slowly.
                      When I attach DC Jack, the laptop will charge the battery and switch on.
                      And now the strange part:
                      1. While the Windows is still loading, and I will remove the DC Jack, the screen goes blank and the Caps Lock light will start blinking 5 times slowly.
                      2. When Windows has been loaded and on desktop, when I unplug DC Jack, it will work normally on battery. While still on battery mode I switch the laptop...
                      06-30-2025, 01:24 AM
                    • Sean Devine
                      Cyberpower 1285AVR (CP1285AVRLCD) reporting wrong battery voltage?
                      by Sean Devine
                      UPS turned off one night and it seemed that the 3 year old batteries gave out.
                      Replaced with a new pair, but the UPS software claimed the battery voltage was only 18 volts and needed to charge. After 24 hours, the UPS claimed only 60% charge and 20 volts (although FWIW, my meter sees 27v).
                      ...then I found various Cyberpower threads here with some guidance on what to check.
                      C1 (22uF) tested at 2, so I replaced that.
                      Put it all back together and didn't see a change on the reported battery voltage. Although, I did run the quick battery diagnostic...
                      03-03-2025, 08:23 PM
