A n00b needs your help - Macbook pro 17" mid2010 820-2849-A
  • jultsu
    • 9
    • Poland
    I have a 820-2849-A which has the following symptoms:
    Screen output is cut in half, the left side being on the right and the right side on the left, with a black void in the middle. Pictured is the Apple Hardware test running from a USB stick:
    Problem is not with C9560, it is holding a nice 1.845v against the ground from the moment the board powers on.
    Trying to boot to macOS hard crashes and computer restarts.
    I used to be able to disable the Nvidia GPU by EFI shell commands, which would restore the screen back to normal and I could boot to macOS and use the computer, but this is not working anymore after a 6 month hiatus from using this machine.
    Would anyone recognize this issue and be able to tell is the GPU fked or can this be salvaged somehow, and point in the direction what to check next?
    thanks.
  • jultsu
    • 9
    • Poland
    Re: A n00b needs your help - Macbook pro 17" mid2010 820-2849-A
    So... after heatgunning very gently the general area of the C9560 the screen output did return back to normal. So I'm guessing its still the poly cap which is causing these issues?
    • piernov
      • Jan 2016
      • 4439
      • France
      Usually C9560 doesn't die on 2849, but you can try to replace it anyway. I don't have high hopes though, the issue will probably show up again.
      • jultsu
        • 9
        • Poland
        The split screen issue returned with a hard freeze after one hour of Youtube playback / 3d benchmarking with the Nvidia chip enabled.
        I might try to concentrate the heat output purely just to the single cap somehow to try and isolate the issue even further.
        Is there any other poly cap that i should be looking at, since the issue most likely isn't with the GPU or the VRAM chips?
        • jultsu
          • 9
          • Poland
          Well, replaced the c9560 with a 6.3v 220uF "C" sized poly cap, no help. Still boots mostly with the broken graphics, sometimes the picture is ok again. Heatgunning the c9560 area doesn't seem to help anymore as well. Would this mean that the GPU has had it?
          • KvnTM
            • May 2018
            • 434
            Heat the GPU to 100°C. The GPU is failing if it works after that.
            But i doubt that the chip will be dead. It looks like a framebuffer issue. A dead GPU usually creates lines, a distorted or garbled screen.
            Give the vram chips a mild reflow with lots of flux.
            Are there no weird artifacts and is everything displayed correctly ignoring the split screen?
            • jultsu
              • 9
              • Poland
              Well, now that applied some alcohol (fairly liberally) to the board around U5340, I started getting some distortion in the picture. This hasn't happened before.
              U5340 because I tried hunting for GFXIMVP_ISNS_IOUT voltage (found something in Rossmangroup's website: https://boards.rossmanngroup.com/for...n-no-backlight) and I also get about 0.02v on R5379, would this give any clues?
              Unfortunately reflowing VRAM chips goes way beyond my skills and equipment, a single component with a few pads/legs might be still doable.
              thanks anyways for the help
              • KvnTM
                • May 2018
                • 434
                Hm this looks like a dying gpu. Just heat it up once while unpowered! 100 - 120C is enough. This doesn't look like a power supply issue.
                • jultsu
                  • 9
                  • Poland
                  Thanks, will try that later. There is some browning around the VRAM chips' glue, this board has probably been heatgunned around that area earlier
                  • jultsu
                    • 9
                    • Poland
                    Hmm okay.
                    Heatgunned the GPU - no difference.
                    Heatgunned the VRAM chips - no difference. Still tiny amounts of artifacting.
                    • Audio Aesthetics
                      Audio Aesthetics commented
                      Editing a comment
                      well wtf man what happened....lol I have the same board and she runs great fast as hell even in 2024 but when she gets super hot she shuts her screen off and then I have to restart! did you scrap the board or did you fix it??
                  • envym
                    by envym
                    Hi everyone!
                    06-27-2025, 08:54 AM
                  • Flasman90
                    Macbook Pro DFU Restore Issues
                    by Flasman90
                    I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                    - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                    - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                    08-30-2025, 10:27 AM
                  • tobeend
                    Bypass mdm macbook m2 ventura
                    by tobeend
                    1. RESET MACOS WITH IPSW
                    a. Power off MacBook, press and hold the power button to enter Recovery
                    b. Open Disk Utility, remove Macintosh HD
                    c. Reboot, connect to the network to Activate Mac.
                    d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                    d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                    e. Release the other keys, but keep holding the Power key for another 10 seconds
                    f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                    05-26-2023, 07:18 AM
                  • SarcasticOP
                    General question about MacBook power rails for repair.
                    by SarcasticOP
                    I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                    • PPBUS_G3H (12.6V-12.8V)
                      • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                    • PP3V42_G3H (3.42V)
                      • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                    • PPVRTC_G3H (3.3V)
                      • This
                    12-12-2024, 05:50 PM
                  • obelix24
                    A2941 Macbook air 15” - 5V 0a
                    by obelix24
                    I’m working on one macbook air 15” m2 that was water damaged.
                    keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
                    i’ve put macbook in shelf and order new screen so i can fully repair it.
                    Now i got the screen and macbook stays at 5v 0a.
                    i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
                    i don’t have schematics so i don’t know where to start can someone help me?...
                    03-27-2025, 01:19 PM
