Acer Swift 3 SF314-51 not powering up - leds flashing
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Acer Swift 3 not powering up - leds flashing
    go to page 89 of the Schematic test all voltages in PIC this is the DC to Dc all voltages must be present
    • rddube
      Aspiring Expert
      • Jun 2013
      • 954
      Hi techtiger,
      Not sure how or where to check those voltages, the board doesn't have any markings except for a number of JPXXXX points. Can you help me identify which component I should be getting those readings from? I can post a sharper image of the power section of the motherboard if that can help. Tks!
      • rddube
        Aspiring Expert
        • Jun 2013
        • 954
        Originally posted by piernov
        Diode is no stuff.
        Soldering on the inductor might be because the guy tried to randomly inject voltage there. We can see that there is some solder on the screwhole on the left, where the ground wire was soldered.
        At that point most main power rails are present but not CPU VCore, probably a good idea to check the enable signal for CPU VCore regulator.
        How would I check the enable signal for CPU VCore regulator? Tks Piernov!
        • KvnTM
          • May 2018
          • 434
          CPU VCore Power Stage Chip is U8002A in Schematic => SIC631CD-T1-GE3
          CPU VCore Controller is U8000A in Schematic => ISL95859HRTZ
          Your VCore circuitry consists of two separate chips. U8002A is the power stage (marked on the photo) which is driven by U8000A.
          You have to find the ISL chip on your board. Maybe there's something in the schematic that is printed onto the board. Finding it would be your job
          U8002A:
          Pin 1 => PWM Input from ISL Chip.
          Pin 32 => VIN = Battery/AC Voltage
          Pin 3 => VCC = 5V
          U8000A:
          Pin 40 => Enable Input of the Controller. (this is what piernov was talking about)
          Pin 34 => VCC = 5v
          Pin 33 => VIN = Battery/AC Voltage
          Be really careful to NOT short any pins on those chips!
          Power cycle the board while measuring PWM/Enable pins and look for any changes. An oscilloscope would be great if you have one.
          Please post a photo of the ISL area to confirm it is the correct one.
          • rddube
            Aspiring Expert
            • Jun 2013
            • 954
            Ok, so I tried to locate the ISL chip on my board, not sure if I found it, but here are photos of both sides of my board. The chip identified with a red border is the other Vcore control chip I think, as it has the same markings as the one you identified just below the CPU.
            As for the ITE chip, I checked with a magnifier the soldering and it is fine, it's the photos that make it look as if it was worked on but it's good.
            If the 3F = 3H chip is not the ISL, not sure where it is unless it is hidden under the heatsink portion - if need be I can remove that and check.
            Tks again!
            • KvnTM
              • May 2018
              • 434
              Tks again!
              Hm looks like both aren't the correct ones.
              Take the heatsinks and all shields off. Also take a look at the schematic if you can't find any markings near the chip on your board.
              It's really bad design to have close to none markings on the silkscreen. Marking on the chip should be 95859HRTZ. There should be no big coil connected to it since it is only a pwm controller. It also could be on the bottom of your board but im not sure.
              • rddube
                Aspiring Expert
                • Jun 2013
                • 954
                Before dismantling it, I just took some resistance readings on the caps near that chip you identified, and here is what I get.
                Is this normal, or does it look like a short?
                Tks.
                • KvnTM
                  • May 2018
                  • 434
                  Tks.
                  Thats normal.
                  19 & 13 Ohm caps are on a cpu power rail which naturally has a low resistance.
                  Not quite sure what the 38 Ohm cap is for.. Try to measure the voltage across it.
                  Does your model have a dedicated gpu?
                  • rddube
                    Aspiring Expert
                    • Jun 2013
                    • 954
                    Ok, so didn't wait and dismantled the motherboard (so can't take voltage readings for now).
                    Here is a photo of both sides of the board without the heatsink. Can't seem to find the chip 95859HRTZ?
                    What should I check now?
                    • rddube
                      Aspiring Expert
                      • Jun 2013
                      • 954
                      Sorry, checked too fast, it is up there on the backside in the upper right corner of the board. It is marked Intersil 95859HRTZ !!
                      • KvnTM
                        • May 2018
                        • 434
                        Yup! That should be it. Now you can start measuring. I'll try to find a way to power the board without keyboard.
                        EDIT: Shorting Pin 27 on the keyboard connector to GND will turn the board on
                        Look for CON3101 in the schematic. Pretty much self explanatory.
                        Best way would be to solder a fine jumper wire to it.
                        • rddube
                          Aspiring Expert
                          • Jun 2013
                          • 954
                          Hey KvnTM, I think I might have found something as I was just probing around the chip to check for shorts, I found the capacitor marked in the photo to be 1.2 ohms, now isn't that a short?
                          All the others seem fine. Also attaching another photo of the same area that seems a little clearer.
                          Let me know what you think and thanks!
                          • KvnTM
                            • May 2018
                            • 434
                            Yeah that doesn't sound quite right to me.
                            It is
                            C8015
                            220PF/50V
                            Remove it and measure the resistance of the cap. Do not power the board after removing it.
                            • rddube
                              Aspiring Expert
                              • Jun 2013
                              • 954
                              How were you able to find it was C8015? I looked at the schematic and tried to follow pin 18 of the chip, but I get lost . Ok, I will remove it and report back, tks.
                              • rddube
                                Aspiring Expert
                                • Jun 2013
                                • 954
                                Ok, removed it and it is not shorted. I still have 1.2 ohms on the board between the 2 points where it was soldered.
                                Does that mean that the problem is with the 95859HRTZ ?
                                  • 21936
                                  Could you post a close up of the area marked in the photo
                                  • rddube
                                    Aspiring Expert
                                    • Jun 2013
                                    • 954
                                    Hey SMDFlea, tks for asking. Here you go.
                                      • 21936
                                      its ok ,must have been the flash ,no damage there.
                                      • piernov
                                        • Jan 2016
                                        • 4439
                                        • France
                                        #39
                                        Pin 18 appears to be connected to VCORE_VSSSENSE, which is basically connected to ground so that seems fine.
                                        • rddube
                                          Aspiring Expert
                                          • Jun 2013
                                          • 954
                                          Ok, so I replaced the capacitor - what should I do next?
                                          I guess I should do the tests that KvnTM suggested - but before I need to solder a fine jumper wire to pin 27 of the keyboard connector. Dumb question, which is pin 27 do I start counting from the right or the left, as there doesn't seem to be an indication of pin 1?
