DABLYDMB8E0 Rev E.
  • mazloum
    • Sep 2012
    • 503
    • Lebanon
    DABLYDMB8E0 Rev E.
    DABLYDMB8E0 Rev E.
    totaly dead with no power, only i get 19v on the source of the first mosfet AON6414A on the drain i get 0.5v , changed it with same results
    i removed the second mosfet with the same result
    http://www.mediafire.com/folder/6xlay65uyyqez/del
  • KvnTM
    • May 2018
    • 434
    Re: DABLYDMB8E0 Rev E.
    Please attach schematics so we can help.
    Either the mosfets are bad or they aren't "switched on". Measure gate voltage.
    • mazloum
      • Sep 2012
      • 503
      • Lebanon
      i cannot find the schemtic,
      the gate is 0v
        • 21889
        is that the right board number, DABLYD or DABLID
        • mazloum
          • Sep 2012
          • 503
          • Lebanon
          dablyd, i forgot to mention that there is 0A when i test it, no current at all
          • mazloum
            • Sep 2012
            • 503
            • Lebanon
            sory the folder above was empty:
            https://www.mediafire.com/folder/6xlay65uyyqez/
            • piernov
              • Jan 2016
              • 4439
              • France
              Attach the files to your message directly.
              Check both MOSFET for short across drain/source/gate.
              Measure resistance to ground after 2nd MOSFET.
              • Jane
                How do you test MOSFET in laptops ?
                by Jane
                I tried to use this method:
                Testing an N-channel MOSFET:
                Step 1: Discharge the Gate (turn off the MOSFET)
                Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                Step 2: Charge the Gate (turn on the MOSFET)
                Now, place the red probe on the Gate (G) and the black probe on the
                09-27-2024, 03:31 AM
              • redbaron1007
                Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                by redbaron1007
                I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                09-09-2025, 11:10 AM
              • AppleLover123
                Asus X712EA 3 volts after the first mosfet
                by AppleLover123
                Hey guys,
                i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                Now i thought something...
                12-15-2024, 07:49 AM
              • MicroSMD Lab
                ASUS ROG Zephyrus GPU Mosfet repeat failure
                by MicroSMD Lab
                The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                01-10-2024, 06:36 AM
              • Scotchmist
                Asus GA502D keeps blowing mosfet
                by Scotchmist
                I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                I have removed the mosfet and can run the laptop no problem
                The MOSFET is FDPC5018SG
                Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                08-24-2024, 02:23 PM
