MacBook Pro 820-2262-A (A1261) intermittent MagSafe light
  • mikiotty
    • Jul 2013
    • 4
    • Italy
    Hi everyone!
    This is my first post here, I hope to solve this problem with your help. This is my first experience on this type of repair, so forgive me if I make some stupid mistakes.
    I have an A1261 17" MacBook Pro (820-2262-A) which has intermittent green light on MagSafe, and when the light flashed I can hear a click coming from the motherboard. The machine would not power on either via the MagSafe of via a known good, fully charged battery. SMC bypass does nothing.
    I checked some voltages and got a regular PP3V42_G3H (3.42 volts), a fluctuating PP18V5_DCIN (between 14 and 16 volts) and no PPBUS_G3H. Time to check for shorts.
    I initially found a short to ground on PPBUS_G3H, even at J6990 (discovered at Q5315), and started going backwards.
    I checked at U7950 and that was ok, I then checked at U5715 and found that pin 3 and 4 of U5715 were shorted to ground, thus shorting PPBUS_G3H via XW7904.
    I traced the short back through R7904 and R7906 and found that pin 21 and 22 (CHGR_CSO_P and CHGR_CSO_N) on U7900 are shorted to ground, thus shorting everything connected to them.
    Removing R7904 and R7906 (the two shorted rails are interconnected via C7902) eliminates the short on PPBUS_G3H and on pin 3 and 4 of U5715.
    Could U7900 be dead and internally shorted to ground? Should I remove it and check if I get no short (not the easy way) or try injecting voltage in some component? Any known bad component that may cause this?
    Thank you!
  • KvnTM
    • May 2018
    • 434
    Re: MacBook Pro 820-2262-A (A1261) intermittent MagSafe light
    This MacBook is well known for GPU failures.
    Avoid all MacBooks before 2012 with dedicated GPUs.
    Even if your problem might be something else your GPU is most likely dead anyways.... There isn't much you can do besides changing the GPU to a revised one which isn't worth it since the laptop is really old.
    • mikiotty
      • Jul 2013
      • 4
      • Italy
      Yes I know but I don't care. I don't plan on using it as my main computer whatsoever, and even if it fails I'll replace it myself.
      Do you have any suggestion on the component that may have failed?
      • KvnTM
        • May 2018
        • 434
        Check all "G3H" Power rails. These have to be always present.
          MagSafe Audio Board MacBook Pro 15" A1226 Left I/O 820-2102 Boardview
          MagSafe Audio Board MacBook Pro 15" A1226 Left I/O 820-2102 Boardview...
          10-28-2024, 03:29 AM
        • shivahoj
          Macbook A1297 Mid2010 820-2361a Magsafe schematic?
          by shivahoj
          Hello, the Magsafe connector of the above Macbook was defective(burnt pins). It is located on a small DC-IN board labeled 820-2361a sitting in the top right corner of the macbook, connected to the main PCB with 5 separate cables.
          While replacing the magsafe, I must have unsoldered and lost a small SMD Resistor that is silkscreen-labeled R1 on the solder side(opposite of the magsafe and ferrite filter). It carries the 1bit-bus to the Amber/green LED driver chip in the Magsafe plug, and without connection to the 1-bit chip in the plug, the macbook won't charge.
          ¿Can anyone please provide...
          12-31-2020, 08:13 AM
        • paparazzo79
          Charging macbook pro mid 2014 15" with magsafe 2 60W charger
          by paparazzo79
          Hi guys.
          May I charge this model with 60 W charger?
          I know it requires 80 W to charge, but don't want to buy one.
          If it specifically requires and 60 W can damage macbook and vise versa, I guess I will have to buy 80 W one....
          09-28-2024, 02:47 AM
        • tobeend
          Bypass mdm macbook m2 ventura
          by tobeend
          1. RESET MACOS WITH IPSW
          a. Power off MacBook, press and hold the power button to enter Recovery
          b. Open Disk Utility, remove Macintosh HD
          c. Reboot, connect to the network to Activate Mac.
          d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
          d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
          e. Release the other keys, but keep holding the Power key for another 10 seconds
          f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
          05-26-2023, 07:18 AM
        • Instafixx
          Macbook A1932 Intermittent Backlight Issue 820-01521
          by Instafixx
          Namaste,
          We have a Macbook Air A2337 that came in for repair , it was drawing 5v with 0.00 -0.01 amps. Went through a couple of guides and figured that it was a DFU issue. Revived the Macbook and it then worked like a charm for 15 days.
          Now it has developed a new problem i.e Intermittent Backlight Failure. Suddenly the Backlight fails and screen goes blank but the laptop is on (checked by playing Music - the laptop screen is blank but the music control respond). Once we close the lid and open it back again, the screen is back on as it was.
          The issue happens very...
          08-11-2022, 04:06 AM
