i have cq56-240st. this can uma?
  • snn70
    • Nov 2019
    • 15
    • Karaman
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: i have cq56-240st. this can uma?
    Where is the motherboard code bro??
    • piernov
      • Jan 2016
      • 4436
      • France
      Most likely no dGPU on this. Issue is dead northbridge AMD RS880M 216-0752001.
      • snn70
        • Nov 2019
        • 15
        • Karaman
        compaq cq56-240st white screen after uma
        Hello there
        I'm new to the forum, I apologize in advance if a mistake.
        I have a compaq cq56 240st
        i want to make uma for this laptop
        motherboard is da0ax2mb6e1 rev: e
        I did what was described in this video (video is here)
        motherboards are identical.
        I removed the ones marked with "GO"
        I moved the ones marked with "chuyen"
        I did nothing to those marked with "them"
        The resistance values look the same as the values in the video.
        After completing all the operations the laptop only shows white screen.
        can you help me find out where the problem is?
        • KvnTM
          • May 2018
          • 434
          Are you sure that your board has a dGPU as piernov already mentioned?
          Take a picture of your board please.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            If the number of amd chip on your board is 3, then its discrete mb. If you have 2 amd chips, then its UMA only.
            • snn70
              • Nov 2019
              • 15
              • Karaman
              My board's pictures
              https://ibb.co/VVdhRz6
              https://ibb.co/YTSP26F
              please help if there is a way to repair this motherboard without bga
              • snn70
                • Nov 2019
                • 15
                • Karaman
                I understand that this motherboard can be made uma. But how?
                • piernov
                  • Jan 2016
                  • 4436
                  • France
                  Please attach pictures to your post directly.
                  As expected, there is no dGPU…
                  • snn70
                    • Nov 2019
                    • 15
                    • Karaman
                    what can i do if there is no dgpu?
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Its already UMA bro. Time to troubleshoot signals.
                      • snn70
                        • Nov 2019
                        • 15
                        • Karaman
                        the display only gives white light. motherboard may be went to heaven?
                        • snn70
                          • Nov 2019
                          • 15
                          • Karaman
                          Should bios software change after Uma?
                          • KvnTM
                            • May 2018
                            • 434
                            Your board DOES NOT have a dedicated GPU and is already running on integrated graphics. It can't be changed to uma because it already is! You'd have to revert all the changes you already made to the board. They were useless and most likely gave you more problems than you had before.
                            As piernov already said your Northbridge is most likely faulty since the integrated graphics is in it.
                            And no there is probably no way to repair the board without bga station.
                            • snn70
                              • Nov 2019
                              • 15
                              • Karaman
                              ok bro. thanks for your effort
