help identifying chip off LA-E801P
  • Mazorca
    • Jan 2017
    • 463
    Hello, this chip is overheating when the power button is pressed. I do not have the schematic. It has a stylized H with letters A03 then FKH0072 underneath.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: help identifying chip off LA-E801P
    seems like a mosfet
    • on/off
      • Oct 2016
      • 333
      • Indonesia
      You must clean the surface of the chip so you can read the sculpture clearly.
      Rub the surface of the chip with the help of thermal grease or cigarette ash, it will help read the mark.
      It is very important to determine whether the mark shows the type of P-Channel / N-Channel or Dual-Channels mosfet.
      the picture looks like a product of Excelliance MOS
      example: EMB20N03V
      • Mazorca
        • Jan 2017
        • 463
        Thank you for your answers. On the board, it is marked as PQ302. I'm doing the thermal paste rub now, no smokers here, good tips.
        • Mazorca
          • Jan 2017
          • 463
          Added new pic, rubbed white thermal paste, then a drop of alcohol. Website of excellencemos keeps timing out, can't get in.
          • R_J
            • 9582
            Seems to be a: emb09a03hp
            • Mazorca
              • Jan 2017
              • 463
              My usual suppliers, digikey and mouser electronics, do not carry that manufacturer. Compatible replacement? in same package, EDFN5*6
              Thank you RJ for the datasheet.
              • Mazorca
                • Jan 2017
                • 463
                Found this one that is similar, listed as 30V Dual Asymmetric N-Channel MOSFET AON6994. It has Id of 50A and 82A in datasheet but listed as 19A and 26A. Original has Id of 15A on both. Is it Ok to use it? Is more amperage better or worse, please advice.
                • R_J
                  • 9582
                  If it can handle more amps, that will be ok. Are you sure this is the problem with the over heating, or is there too much load that is causing the mosfet to overheat?
                  • Mazorca
                    • Jan 2017
                    • 463
                    chip displays 0.4 ohms in both directions when checking from D1 to S1, 42Kohms from D2(neg probe) to S2(pos probe) and 0L from S2(neg probe) to D2(pos probe) also there is 0.4 ohms between D1 and D2
                    Laptop went up to over 2 amps when pushing power button, had to disconnect right away, I burned my thumb when pressing chip. After it was removed, laptop goes to just over 500 mA, but fan wont start. It didn't start before removal either.
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                    • DynaxSC
                      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                      by DynaxSC
                      Hi
                      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                      08-04-2025, 12:20 PM
                    • Loki_Fido
                      Requesting help identifying chip in Macbook Pro A2485
                      by Loki_Fido
                      Hi ya folks,
                      I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
                      It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
                      I replaced it and the SSD are fine. No more shorts.
                      But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
                      But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
                      Chip marking...
                      08-07-2025, 10:17 PM
                      by SMDFlea
                      Bad...
                      09-02-2021, 04:40 PM
                    • trepachka
                      Help identifying this chip for Yoga 7 16IRL8
                      by trepachka
                      This chip is shorted thru. Based on what I see, it's either a 3.3V or 5V buck converter, just my guess. The markings on the chip state "S2=AB".
                      A photo of the chip is attached.
                      Thank you....
                      06-22-2025, 11:13 PM
