help identifying chip off LA-E801P
  • Mazorca
    • Jan 2017
    • 463
    Hello, this chip is overheating when the power button is pressed. I do not have the schematic. It has a stylized H with letters A03 then FKH0072 underneath.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: help identifying chip off LA-E801P
    seems like a mosfet
    • on/off
      • Oct 2016
      • 333
      • Indonesia
      You must clean the surface of the chip so you can read the sculpture clearly.
      Rub the surface of the chip with the help of thermal grease or cigarette ash, it will help read the mark.
      It is very important to determine whether the mark shows the type of P-Channel / N-Channel or Dual-Channels mosfet.
      the picture looks like a product of Excelliance MOS
      example: EMB20N03V
      • Mazorca
        • Jan 2017
        • 463
        Thank you for your answers. On the board, it is marked as PQ302. I'm doing the thermal paste rub now, no smokers here, good tips.
        • Mazorca
          • Jan 2017
          • 463
          Added new pic, rubbed white thermal paste, then a drop of alcohol. Website of excellencemos keeps timing out, can't get in.
          • R_J
            • 9535
            Seems to be a: emb09a03hp
            • Mazorca
              • Jan 2017
              • 463
              My usual suppliers, digikey and mouser electronics, do not carry that manufacturer. Compatible replacement? in same package, EDFN5*6
              Thank you RJ for the datasheet.
              • Mazorca
                • Jan 2017
                • 463
                Found this one that is similar, listed as 30V Dual Asymmetric N-Channel MOSFET AON6994. It has Id of 50A and 82A in datasheet but listed as 19A and 26A. Original has Id of 15A on both. Is it Ok to use it? Is more amperage better or worse, please advice.
                • R_J
                  • 9535
                  If it can handle more amps, that will be ok. Are you sure this is the problem with the over heating, or is there too much load that is causing the mosfet to overheat?
                  • Mazorca
                    • Jan 2017
                    • 463
                    chip displays 0.4 ohms in both directions when checking from D1 to S1, 42Kohms from D2(neg probe) to S2(pos probe) and 0L from S2(neg probe) to D2(pos probe) also there is 0.4 ohms between D1 and D2
                    Laptop went up to over 2 amps when pushing power button, had to disconnect right away, I burned my thumb when pressing chip. After it was removed, laptop goes to just over 500 mA, but fan wont start. It didn't start before removal either.
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                      by SMDFlea
                      Bad...
                      09-02-2021, 04:40 PM
                    • trepachka
                      Help identifying this chip for Yoga 7 16IRL8
                      by trepachka
                      This chip is shorted thru. Based on what I see, it's either a 3.3V or 5V buck converter, just my guess. The markings on the chip state "S2=AB".
                      A photo of the chip is attached.
                      Thank you....
                      06-22-2025, 11:13 PM
                    • tyler123456
                      Need help identifying an IC chip on a Bush DAB radio (BD-1801)
                      by tyler123456
                      Not sure whether anyone can help but I'm trying to identify the IC chip in the photo below.
                      I purchased a faulty Bush DAB radio (model # BD-1801) and identified that an IC chip was blown on it. Unfortunately, I couldn't read the manufacturer name / model number of the IC chip.
                      I purchased another (working) BD-1801 so that I could open it up to find out the IC details - but the IC chip details are missing (as you can see in the photo.)
                      Given the two huge blobs of solder either side of it I'm guessing it regulates power(?)
                      Anyone...
                      08-16-2024, 12:51 PM
                    • BMCappelletti
                      Asus Chromebox CN62 - wrong chip put on BIOS reader
                      by BMCappelletti
                      Long story short:
                      - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                      - gave the computer to his son a couple years later
                      - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                      - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                      (seems like the story was not that short)
                      He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                      01-08-2025, 07:27 PM
