Unknow transistor
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Unknow transistor
    It's marked as Q4 so I think is a transistor or something like this. Tester return unknow or damage component, what kind of transistor is ?
    It's possible it's a TI431 ?
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Unknow transistor
    this?
    https://www.aliexpress.com/item/32422924466.html
    • R_J
      • 9532
      Is the component itself marked as Q4 or is that its designation on the board? Got a picture?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Which mobo?? Any code/laptop model??
        • jasko_jacker
          • Oct 2014
          • 1137
          • italy
          sorry there was a photo upload error
          • vinceroger69
            • Mar 2012
            • 6714
            my guess tl431
            • KvnTM
              • May 2018
              • 434
              my guess tl431
              Not quite sure. Take a look at the datasheet for sot23 markings. Search for PACKAGE OPTION ADDENDUM in the pdf.
              TL431 is a voltage reference and wouldnt be marked as "Q" on the board.
              OP: Try to get a schematic for that laptop. The circuit will tell you more.
              • R_J
                • 9532
                I would also say it's a tl431 reference ic, I suspect it it in the secondary of a smps near the optocoupler
                • Sus256
                  HISENSE 65E7KQ PRO - no boot
                  by Sus256
                  Hi all!
                  HISENSE 65E7KQ PRO
                  RSAG7.820.13512 - chassis
                  MT9618BAATAB - cpu
                  RSAG7.820.12059 - power
                  HD650Y3U77 - panel
                  KLM8G1GETF - emmc
                  The TV does not turn on, the standby indicator is on. All voltages are present.
                  Emms is dead. Not readable, not detected.
                  Replaced emmc.
                  But with another dump there is no launch
                  Terminal log
                  UART
                  AC_ON
                  RPMB key is not yet programmed
                  HASH1_VERSION=0x00000000 64bit
                  E-B
                  FDE enabled
                  layout pattern onebin by SAR7,0...
                  06-01-2025, 02:11 AM
                • appie1206
                  Transistor or diode marked M51Y?
                  by appie1206
                  Can somebody tell me what this..? See picture.
                  H51y ur m51y...
                  If u know wich can us send me link so i can order it.
                  Thank you...
                  04-11-2022, 03:01 AM
                • Superbee_dad
                  Sharp 80” long short flash backlight error - Help
                  by Superbee_dad
                  Hello Sharp TV experts
                  Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                  > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                  > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                  01-24-2025, 11:51 PM
                • ItepK
                  Panasonic TX-P42G30E green light blinking, no video, no audio
                  by ItepK
                  Hey everyone!
                  I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                  This post describes my entire troubleshooting process of this TV.
                  When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                  I've taken the unit apart, and I've started to check some voltages:
                  • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                  12-22-2023, 05:06 AM
                • magneh
                  Behringer Eurolive B205D repair - help identifying transistor
                  by magneh
                  Hello
                  Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                  Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                  After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                  I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                  Still, I need to replace this transistor....
                  06-18-2025, 02:34 AM
