asus ux305ca was dead, now works, but battery is not charging
  • rediii
    h???, spurrrn
    • Mar 2018
    • 487
    • somewhere in europe
    hello guys,
    i fixed an asus ux305ca which was not turning on at all. gate-vcc was missing on the first fet (check picture), i removed it and bridged source and drain with a wire (finding the gate-regulator is a rabbit hole...). the battery of the device was completely dead and i think it fried the mainboard. i just bought a new battery (aftermarket, but ok) and this would not charge at all. if the battery is not plugged in, i can measure around 0.845 v on the coil (check picture with mark). i think the battery ic is bad or/and there is more missing than the first gate-vcc of the first fet after the charging port. if the battery is plugged, the laptop ist starting, but the charger voltage would not pass through the dcdc-step down for the right battery charging voltage. laptop is otherwise totally fine. thanks in advance! any ideas?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: asus ux305ca was dead, now works, but battery is not charging
    That wont work. The gate of the first mosfet will be equal to souce voltage in this arrangement whereas it should be higher or lower then source depending on whether its n channel or p channel mosfet. Without the correct gate voltage at dc in mosfet, charging circuit will never work whatever you do.
    • rediii
      h???, spurrrn
      • Mar 2018
      • 487
      so there are missing multiple gate-vccs on the board? or do you think the charger AND charging gate are coupled? i don't have any schematics, it's a waste of time to search for the gate-elements...
        • 20848
        Boardview: https://www.badcaps.net/forum/showpost.php?p=818861
        • rediii
          h???, spurrrn
          • Mar 2018
          • 487
          Originally posted by SMDFlea
          thanks man, but which program do i have to use (openboardview cant open the file)
            • 20848
            openboardview can open it with the .fz key.
            • rediii
              h???, spurrrn
              • Mar 2018
              • 487
              do you know another free software then? would help me a lot, thanks
                • 20848
                Read your PM .
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  You need to have some patience in trouble shooting a laptop mobo. That's all i want to say.
                  • rediii
                    h???, spurrrn
                    • Mar 2018
                    • 487
                    already solved the problem, thank you guys! sry, but i have a lot of work to do, so no time
                    • brew99
                      • Jan 2019
                      • 132
                      So what was the solution then?
                      • rediii
                        h???, spurrrn
                        • Mar 2018
                        • 487
                        battery ic was faulty and i replaced n-channel mosfet near charging port!
                        thank you guys!
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
                        • Gregoriy Kim
                          Asus Vivobook M3502Q, no power through USB-C, works on battery.
                          by Gregoriy Kim
                          Hello everyone!
                          Need help with Asus Vivobook M3502Q, Ryzen 5.
                          First time working with failed power supply via USB-C ports. no schematics available.
                          Symptoms:
                          suddenly turned off and does not turn on,
                          Upon first observation, turned out both CSD87501 mosfets had unsoldered due to overheating.
                          Manually charged battery and laptop works on battery
                          Soldered 2 new CSD87501 on board, but it didn't solve the issue.
                          there is 3.3V and 1.6V from TPS65994. and it talks to charger, so charger sends 20V, but no load. There is 20V...
                          04-13-2025, 03:25 AM
                        • bykanovm
                          Thinkpad W541 Works from the mains and charges the battery only when it is turned off
                          by bykanovm
                          Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
                          If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
                          If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
                          even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
                          Also, the laptop does not turn on without...
                          04-02-2025, 02:45 AM
                        • ivangserrano
                          ASUS UX303UB REV2.2 WORKS ONLY BATTERY
                          by ivangserrano
                          Hello
                          I have an ASUS UX303UB that only turns on with the battery connected, it doesn't turn on only with the charger connected.
                          With the battery and charger connected, the computer turns on but does not charge and I can see some consumption at the source, it seems to me that the charger is taking over.
                          In the work environment I can see that the battery is at 24% and does not charge or discharge.
                          I checked the 24780s load ic and I have the following voltages.
                          24780s
                          vcc - 18.85
                          24v acdriver
                          acok 1.3v
                          acdet 2.6v...
                          06-29-2024, 06:35 AM
                        • Iherduleikgemz
                          Asus FX505DY - Battery not charging - BQ24780S
                          by Iherduleikgemz
                          Hello everyone
                          I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
                          I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
                          01-13-2025, 03:54 PM
