Is there any solution for unlocking efi password for 2018 and 2019 models?
macbook pro 2018 efi unlock
This topic is closed.
Re: macbook pro 2018 efi unlock
SMCProg allegedly is able to do it.. But.. The tool is expensive and as far as I know, they start shipping out in december. And thus far it still seems a bit suspicious because I haven't seen any good videos about it in action.
Not saying it's impossible though.. Apple products are badly designed anyway so unlocking them should be far from impossible.Comment
SMCProg is a scam to me, until they actually prove they are capable of what they're claiming, and not just what other tools do already.
As for unlocking, as a bootrom exploit has apparently recently been found in a lot of iPhone CPU DFU mode, maybe T2 chip is affected as well (it's pretty much an iPhone CPU and has DFU mode). A direct access executing unsigned code is a good attack vector to bypass the security. For now, attacking T2 is very hard because there are not a lot of attack vectors unlike iPhones where you have the whole user interface that you may be able to compromise.
Overall Apple security is not bad, but like everyone they made mistakes in the past, and they will continue to make mistakes in the future. It is more about making the wrong mistake at the wrong place at the wrong time, while not having safety nets in place.Last edited by piernov; 10-03-2019, 12:49 PM.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
If you use fake documents to fool Apple or if you have mole at Apple/AASP...OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
SCBO is supposed to be tied to a specific machine. I haven't seen a keygen around.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
No, I don't have access to Apple RSA signature.Comment
@RethoricalCheese sorry i wrong use quote. But thanks for U time for answer.
Can u help me generate SCBO for this macbook.
****************Comment
I don't think scbo files are any more available anywhere apple blocked all the sources and without help of apple cant be unlocked in any ways.In the past some machines were done, but now i think no more via scbo at least, may be in future.Few people claimed they can do but now they don't reply back.Last edited by Aditya11ttt; 01-19-2020, 01:25 PM.Comment
No commercial service here, closed.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
by bouchhi
i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
I need help or information?
Does anyone have the minat2 activator 1.4 software?
Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
Thank yo...-
Channel: BIOS Requests ONLY!
03-12-2025, 10:14 AM -
by robkaHi,
my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
After that the Macbook was dead. It isn't charging anymore.
The USB-C Port where the charger was plugged is burned. Also The Cable and the... -
by envymHi everyone!
I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...06-27-2025, 08:54 AM -
by MyronViegasHey guys,
I got a MacBook Pro a1989 820-00850-A dead for repair. The MacBook itself was off for a month or so and it didn't power on. I tested using ammeter and it was stuck on 5v. Opened the machine and found a short on ppbus_g3h, corrosion near the right spkr_amp. removed the spkr_amp and saw short on ppbus_g3h. plugged in to power, boosted to 20v .600A and then back down to .300A. Trackpad was clicking when on .600A but no image etc.
Later, I tried again but it dropped down to 5v and never boosted back to 20V. checked board again and found ppbus_g3h shorted again....10-06-2025, 08:45 AM -
by Clarify4082Hi,
I have a A1932 Macbook Air with Bootloop.
I already replaced the battery with a new one and reset NVRAM and SNC.
When I start the Macbook the Screen is coming on (no Logo) and switches of after a few seconds. If I start without the trackpad and keyboard it stays on longer.
If I use diagnostic (Option+D), recovery (Option+R) I always get the Apple logo and it go into online-Recovery. Even if I boot the installer from a USB-stick it ends up in online-recovery. Sometimes it crashed short after entering the wifi password, sometimes it loads the recovery... - Loading...
