dell e6530 error cpu failure.
  • inkman
    • Sep 2019
    • 55
    • uk
    orignally posted in wrong section.
    When i turn this laptop on power led lights up,fan turns slowly,dvd drive lights
    up after that laptop turns off. After that it turns on again on its on and repeats
    same steps.There is blank screen,does not get to dell logo,F2-F12 does not work. After repeating few times three led lights up indicating error code cpu
    failure.
    I have swapped working cpu with same result.
    I have put in new ram with same result.
    When i start laptop with key "d" pressed the screen goes thro all diferent colors
    then switches off.
    I have removed rtc battery overnight and put it back in the morning, turn laptop on and it goes thro all above steps but this time there are NO error led
    for cpu failure showing any more. The laptop charges battery ok.
    The laptop has i7 quadcore with NVIDIA gpu.
    Motherboard is Qala1 LA-7762P.
    Is it power issue, gpu faulty or bios issue?
    Can anybody help me sort this problem please.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: dell e6530 error cpu failure.
    Schematic available for this model. You need to measure power rails first. No harm in flashing bios but do make backup of original bios.
    • inkman
      • Sep 2019
      • 55
      • uk
      I have the schematic, do i check all power rail or just cpu?
      • Techtiger
        • Oct 2014
        • 1602
        • france
        You have to check CPU CORE, GFX CORE , DDR REF , DDR VTT check all inductor coils
        • inkman
          • Sep 2019
          • 55
          • uk
          The problem has been solved by flashing bios.laptop is working now.
          Thanks for your help.
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Themi
            Dell XPS 13 9310 2 amber 4 white memory failure
            by Themi
            I have this laptop a dell XPS 13 9310
            Power on is ok, stuck at dell logo flashing 2 amber and 4 white (link dell service manual) 2,4 Memory or RAM (Random-Access Memory) failure​
            I believe this is the spec from using micron tool to decode marking
            Images of the ram
            I am thinking to replace but wondering if there is a possibility to test while in circuit to find the faulty module? I am doubting there is any reasonable test possible while in circuit as most ram ICs I have tested previously, I have done while off board / removed.
            Another...
            11-24-2024, 09:06 AM
          • Amber TC
            [NOT A RESCUE BIOS] Dell Latitude E6530 Rare Factory BIOS (Revision A86)
            by Amber TC
            ⚠️ Not a Rescue BIOS. Flash at Your Own Risk. ⚠️
            This is not A17.
            This is not listed on Dell's support site.
            This is an unreleased internal firmware revision recovered from a university loaner Latitude E6530... and it possibly bricked the system it came from.
            It is from the 8 MB Winbond W25Q64 chip. Could be nothing burger but given the anomalies this is a very interesting firmware dump.
            Firmware collectors and reverse engineers might find this useful, It contains certs, modules, and DXE drivers not present in A17. This is likely...
            04-17-2025, 03:54 PM
          • joesmoe91
            Dell Precision 5530 15" died to blown chip. Replaced chip and now only get momentary fans, lights, no screen or boot
            by joesmoe91
            My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights....
            02-22-2024, 07:38 PM
          • duder
            Dell E6530 Bios Request
            by duder
            Could someone please have a look at this bios? I have brought Dell back to life with another BIOS but would like to keep ME Region. I am still learning to use ME Analyzer. Thanks in advance.
            That is actually a Dell E6530. I made a typo with the filename....
            11-24-2023, 12:27 PM
