acer (la9532p) power on no display
  • karimreza2
    • Mar 2018
    • 23
    • Bangladesh
    help
    • 20420
    Re: acer (la9532p) power on no display
    What tests have you done so far,its no good just saying help. Have you tried a different charger,memory,cmos battery.. .Have you taken any voltage readings
    • karimreza2
      • Mar 2018
      • 23
      • Bangladesh
      there have all voltages such as 3v,5v,1.3v,1.05v.1.8v.core voltage. i just flash bios.but same
      • petehall347
        • Jan 2015
        • 4424
        • United Kingdom
        try external monitor
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          What is the voltage on PIN 1-3 and PIN4 of Q5(AO4304)??
          • karimreza2
            • Mar 2018
            • 23
            • Bangladesh
            pin1 topin 3=1.35v
            pin4=No v
            pin5 to pin8=1.35v
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Ram slot pin30 voltage?? PLT_RST present?? Did you flashed both bios?? I beleive there are 2 bios on this board-2mb+4mb
              • karimreza2
                • Mar 2018
                • 23
                • Bangladesh
                ram slot 30pin no voltage, yes i flash bios, there are one bios only 4 mb. another is DY component. PLT RST present
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Since you have zero volt on DRAM_RST pin(should be 1.35 if pc3-L) means gfxcore is also missing. I'll still suggest to flash known good bios or probe ram circuit.
                  • karimreza2
                    • Mar 2018
                    • 23
                    • Bangladesh
                    please attach a good bios file
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      post it in bios section first
                      • Bonaventure Vigil
                        ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                        by Bonaventure Vigil
                        Dear All,
                        Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                        At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                        12-12-2024, 10:22 AM
                      • ithe
                        Acer Aspire V5 571P 6499 power on but no display or no access to BIOS
                        by ithe
                        I am using this Acer Aspire V5 571P 6499 laptop for a long time. Laptop does powers on, but no display after properly shutdown while in its last working condition.
                        Laptop model - Acer Aspire V5 571P 6499
                        MoBo - Husk MB 11309-4M 48.4TU05.04M
                        HW config. i5, 4 GB RAM,250GB SSD, Windows 10 OS
                        status when laptop turned on
                        no display no logo no BIOS access
                        status - power led on, charging led (when power adaptor connected), led on power switch glow when power is on.
                        fan spins and stops for a minute and again start spinning....
                        10-31-2023, 01:59 PM
                      • aladin2l
                        ACER NITRO 5 AN515-52 DH55VF LA-F591P POWER ON NO DISPLAY
                        by aladin2l
                        hello guys i have here ACER NITRO 5 AN515-52 DH55VF LA-F591P POWER ON NO DISPLAY i think it boots beacuse the keyboard lits the fan spin 2 times when power on because i think bios responces without cmos battery also when charger connected then charger plug in it also tones plug and replug my main problem is it wont display even in monitor
                        heres my voltage and resistance reading for all the coil or inductors i hope someone can help me where to find the missing voltage on +VGA_CORE and +VCC_GT
                        PL1302 1.3V
                        PL7202 0.9V
                        PL8301 1.0V
                        PL8106 0.9V
                        PL8305 0.9V
                        PL8306...
                        10-16-2024, 05:17 AM
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
