samsung np300e4z screen is flickering when battery only
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need help on this samsung np300e4z-a02ph the laptop is working fine with the charger plugged in only or battery and charger both plugged in working fine, but the problem is when i pullout the charger battery only plugged the screen is flickering.I have already tried replacing new battery still the same issue, replacing brand new screeen still the same issue. anyone please help on this please
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: samsung np300e4z screen is flickering when battery only
    I remember somebody had a similar problem in this subforum. he has got many good recommendations. First, you should find that thread and provide a link here.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      That thread was started by me and it was Asus laptop. Replacing the screen solved my issue.
      About the case in hand, I'll suggest you measure LVDS pinout voltage related to LCD Power(NO need to measure data lines) and compare the difference in readings-with batt only/with adapter only.
      • String2016
        • Nov 2015
        • 2238
        • philippines
        thanks for the response. i dont have schematic for this can please suggest what pin number on the lvds connector to measure please?
        • R_J
          • 9583
          I found a schematic for a 300e4a, board number BS41-016661, I can upload it if you think it would be helpfull.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            how many pins on lvds connector?? If it is 30 pin, you can follow NP300E4A schematic which is freely available.
            • String2016
              • Nov 2015
              • 2238
              • philippines
              it has 40pins connector
              • R_J
                • 9583
                Here is the one I have, it's not very big so have a look, maybe it will be helpful
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Check this
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
                  • Ado02
                    Lenovo Thinkpad X1 Gen 10 - Flickering Screen
                    by Ado02
                    We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the Intel® Iris® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
                    The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
                    12-16-2024, 02:33 PM
                  • Chrissygizmo
                    samsung galaxy ao2s very temperamental after screen replaced
                    by Chrissygizmo
                    Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                    Ive eventually managed to get it on and working but it's very temperamental...
                    The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                    05-26-2024, 12:05 AM
                  • JunkmanJimbo
                    Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                    by JunkmanJimbo
                    Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                    No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                    Please help. Thanks in advance!
                    08-12-2025, 11:45 AM
                  • Kiberge
                    Samsung LH82QENELGC/EN Help needed - Static line on screen
                    by Kiberge
                    HI guys!
                    I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                    I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                    the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                    This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                    04-22-2024, 11:28 AM
