Hp 250 g2 keyboard not working
  • infoplus
    • Aug 2017
    • 83
    • ALGERIA
    Hi i m working with HP laptop 250 g2
    Board: osamu2_bt_hpc mv_mb_v1
    its come with broken dc jack and damaged IO
    I changed IO and flash bios file
    turn on but touchpad and boton not working
    keyboard worked only in bios in windows mode not working
    please help me....
  • fichamba
    MSI GL75 Leopard keyboard (almost) not working - HELP
    by fichamba
    Hello everybody:
    Let me put all the laptop's info before describing the problem:
    BRAND: MSI
    MODEL No.: MS-17E7
    SKU: GL75 Leopard 10SEK-261XES-BB71075H16GXXDXX
    MoBo: MS-17E71 VER. 1.0
    This laptop arrived to fix the broken left hinge, due to a hit. The hinge was repaired, and when I went to check it out, everything worked well, but I observed certain artifacts (mainly random lines) in the screen.So I decided to remove the screen bezel again, and I saw certain damage to the main LCD harness.
    This time I also observed that the right...
    10-09-2024, 04:53 PM
  • SuperAman
    Keyboard replacement not working issues with Win 10/11 (2) different laptops
    by SuperAman
    I have had an issue that I've never come across in all my years of laptop repairs and it has happened twice in the last couple of weeks. The issue occurred on 2 laptops.
    1. The first laptop a Lenovo Yoga 7 convertible 14 inch 13th gen i7. This laptop came in working, customer wanted to replace the top keyboard assembly for cosmetic reasons so I replaced the keyobard assembly and put their touchpad in it. After booting into windows it would not work, so I assumed I needed to update it or something. Since they didn't give me the Admin account, as it was a company laptop and the...
    08-31-2024, 07:30 PM
  • Vliegenier04
    Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
    by Vliegenier04
    Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
    I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
    Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
    06-16-2025, 12:03 PM
  • hopkok
    Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
    by hopkok
    Hi masters, I need your help.
    I am working on Lenovo Legion 16ITHg6
    Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
    INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
    My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
    AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
    Power LED is not working as well, power button working well.
    UI26 ??? is there any firmware too? Powered by +3VALW_AG.
    Motherboard...
    05-04-2025, 09:35 AM
  • ronaldopdias
    Dell Alienware x17 R1 - Keyboard not working
    by ronaldopdias
    Symptoms:
    No keys work apart from F1, F7, F12 function keys such as keyboard brightness, touchpad enable/disable.
    Keyboard RGB works okay and might be adjustable.
    VERY occasionally it may function but most of the time it is dead.
    The fault is down to the USB data lines not going low when the bus is idle. The keyboard connects over USB, so the issue on the USB data bus causes it to stop functioning.
    The fix is to fit a 1K resistor to the daughterboard that the keyboard + trackpad connect to. The daughterboard is located beneath the battery. The resistor...
    05-13-2025, 04:50 AM
