820-4924 Won't run on battery
  • BrickBreaker
    • 52
    4924, liquid damage near the magsafe conn, R7005 and D7005 replaced, got power.
    Battery charges. Won't run off battery. Shutsdown immediately upon remove magsafe.
    Tried replacing ISL, Q7130, Q7155 same time. No change.
    With just battery, PPBUS measures 12.64V
    Won't power on with power button on battery only.
    Tried three total batteries, orig plus two testing batteries.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: 820-4924 Won't run on battery
    PP3V42_G3H on battery only?
    Are you sure PPBUS_G3H is 12.64V on battery only? (rather than with Magsafe connected)
    • BrickBreaker
      • 52
      Solved. The hint is in the original problem, first line in the post. What voltage did I measure, what was missing, and what soldering mistake did I make?
      • BrickBreaker
        • 52
        Ah you got it already, no 3v42 was not present on battery only. PPBUS was indeed 12.6V though. Hint problem wasn't a short but an OL.
        • BrickBreaker
          • 52
          It lives! Still need to place a tpad connector but I did the hard stuff and the vital stuff.
            12-31-2023, 06:04 AM
          • flat-earther
            Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
            by flat-earther
            I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
            To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
            I have opened the camera and I think there is enough room to add something inside to accomplish this:
            The camera is powered by a 3.7V nominal single cell lithium ion battery.
            So I need to connect another battery in...
            06-08-2025, 02:00 AM
          • mkdj
            by mkdj
            Mark and model: ASUS X571
            Tests already made:
            - I have removed...
            07-14-2025, 09:16 AM
          • huzo
            HP ELITE X2 1013 G3 weird battery issue
            by huzo
            Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
            01-31-2025, 12:09 AM
          • trepachka
            iPad Air A1475 Boot loops after replacing battery
            by trepachka
            This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
            The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
            I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
            11-08-2024, 03:17 PM
