Battery not detecting on X450UP CORE I7 8TH GEN
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    x450up rev. 2.0 After upgrading its ddr4 ram I cant power on the laptop using its battery installed and I can only power up thew laptop using its ac cord. Booting on os battery is detecting but if you remove the ac power laptop turns off immediately ..
    I want some advice around here
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Battery not detecting on X450UP CORE I7 8TH GEN
    check for shorted caps and/or shorted fet on battery output line.
    • zhang
      • Jun 2017
      • 50
      • Indonesia
      please take photo of the motherboard please
      usually for asus, some of bolt is connected to ground of battery, so if the is not tighten enough, the battery can not be detected
      try to tighten all the bolt
      • kalilinux25
        • Mar 2018
        • 2093
        • ZAMBOANGA SIBUGAY
        AHAHA my godd thnask ive result the problem thansk sir I tried to screw all thing and it wnet down good
        • zhang
          • Jun 2017
          • 50
          • Indonesia
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • mkdj
            by mkdj
            Mark and model: ASUS X571
            Tests already made:
            - I have removed...
            07-14-2025, 09:16 AM
          • techfreak9356
            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
            by techfreak9356
            09-14-2023, 11:10 PM
            NVDC charger configuration...
            11-05-2024, 03:28 PM
          • ferah831208
            by ferah831208
            03-18-2025, 01:18 AM
