Lenovo Air 14IKBR EYG20 EYG10 NM-B601 charge problem
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    The notebook was totally death, no schematic or boardview so
    I found out that the EC was in short, so I replaced and reprogrammed it.
    I don't know if the battery was charging but now the owner tells me that the LED turns on and off immediately and the notebook worked
    with the battery until it is discharged.
    The two mosfets, controlled by the BQ24780S, are ok but no signal is received at the gates, ac is detected. Before doing other checks is it possible that the problem is on the EC?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo Air 14IKBR EYG20 EYG10 NM-B601 charge problem
    Ec firmware can be the issue but Ec chip not likely to be bad. Extract ec firmware from lenovo official update and reflash ec to be sure.
    • shibu
      • Apr 2016
      • 28
      • uae
      hi EC firmware can be the issue you can also extract the firmware from main bios
      • shibu
        • Apr 2016
        • 28
        • uae
        that laptop works by adaptor?
        • jasko_jacker
          • Oct 2014
          • 1137
          • italy
          Works only with battery, no with adapter. I have downloaded the EC firmware from a paysite but I have downloaded the bios from lenovo also , there are two problem, first I think there is 6MB instead 8MB so it not contain EC firmware, second it's in .exe and uniextract it's not be able to unpack it (the battery it's full empty and I can not use lenovo to unpack it)
            • 20990
            Test BQ24780S voltage,pins 4,5,6. https://cdn.badcaps-static.com/pdfs/...2a8abce3d9.pdf
              • 20990
              To unpack use innoextract first,then 7-zip or winrar to extract the exe,then cut bios and EC using hex editor, or you can use innoextract first then change the platform.ini file from BatteryCheck=1 to BatteryCheck=0 to disable the battery check.
              http://constexpr.org/innoextract/#download
              • jasko_jacker
                • Oct 2014
                • 1137
                • italy
                I extracted from fd file the 8192 K bios.bin but I don't find any ec file into this and into the two block I deleted from the fd file.
                Usually I repair asus and I have some difficulties with these procedures.
                  • 20990
                  Here`s the EC . In the fd file do a text search for ITE to find the EC.
                  • jasko_jacker
                    • Oct 2014
                    • 1137
                    • italy
                    Ok,
                    many thanks
                    • shibu
                      • Apr 2016
                      • 28
                      • uae
                      hey buddy your problem solved or not ? i thing the problem with not EC you need to check main power line FET's and the pin 28 vcc on bq24780s it's should be 18v to 20v
                      if not there is a diode and a resostor from main line the resistor mostly value are 10 to 20 ohms!
                      • jasko_jacker
                        • Oct 2014
                        • 1137
                        • italy
                        Not solve yet due for searching another ec firmware, bq24780s has the 19v on pin 28 and
                        ACDET -> HIGHT
                        ACOK -> LOW
                        REGN -> 6 V
                        BTST -> 5.7 V
                        CMPIN and CMPOUT -> 0.5 V
                        Is missing ACOK: from datasheet:
                        "Active HIGH AC adapter detection open drain output. It is pulled HIGH to external pullup supply rail by external
                        pullup resistor when a valid adapter is present (ACDET above 2.4 V, VCC above UVLO but below ACOV and
                        VCC above BAT). If any of the above conditions is not valid, ACOK is pulled LOW by internal MOSFET. Connect
                        a 10-kΩ pullup resistor from ACOK to the pullup supply rail."
                        • brew99
                          • Jan 2019
                          • 132
                          As you say, the ACOK needs to be HIGH. Did you try changing the BQ chip? Without the ACOK being HIGH, you most likely won't get the gate signal to the ACFET
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            ACOK signal ineeded is the issue. Kbc can be the issue as its related to kbc_aux power (eg dell cedar 13269 mb) though its very difficult to arrive at any conclusion without schematic.
                            • jasko_jacker
                              • Oct 2014
                              • 1137
                              • italy
                              I replaced the EC but 3.3 power voltage disappears when this ic is in place, if I remove it the 3.3 v appears, but the new ic as the old don't show with multimeter any sign of short. I don't remember if the presence of 5v ALW is related to EC, but I don't detected 5v ALW . someone can identify the 3.3 / 5 ALW ic to search the datasheet. thanks
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Awv = sy8286brac
                                BAC=SY8288CRAC
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  You can refer to Quanta G71 schematic.
                                  • agswireless
                                    Lenovo Y50-70 (LA-B11P) no charge problem
                                    by agswireless
                                    ok so I have this Lenovo y50-70 touch that has a no charge problem, maybe someone can point me in the right Direction since I cannot find a schematic for Borderview
                                    what are you guys opinion on where to start to check why its not charging?
                                    Back story:
                                    I bought this with a bad charging port, previous owner stated it charge fine but his kid kicked the cord and rip the plug and port out.
                                    so I ordered a new one, but when I was replacing the plug the open wire touch and made a spark because I completely forgot to unplug the battery.
                                    so I went a head changed out...
                                    01-30-2024, 01:39 AM
                                  • s_specialist
                                    Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
                                    by s_specialist
                                    Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
                                    07-07-2025, 11:47 AM
                                  • perzyk23
                                    Lenovo T580 - LCD Panel problem - error 0288
                                    by perzyk23
                                    Good morning,
                                    I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                    10-25-2024, 12:42 AM
                                  • konradx
                                    Lenovo Thinkpad T15 Touchscreen problem bios
                                    by konradx
                                    i have problem witch Lenovo T15, my LCD display was demaged, i buyed New LCD, Touch screen version. Problem is LCD Working but Touchcreen not working, i wrinted to seller . He sended to me another LCD, but still not working. I have to Lenovo T480s with touchcreen LCD and that display and touch work. I think that is somethink like whitelist support LCD in BIOS. Someone have the same problem?
                                    That is my DUMP.
                                    My device:
                                    SN: PF29Y4N6
                                    1s20S7S2WF00PF29Y4N6
                                    MB: GT4A0 GT5A1 GP4A0 GP5A1 GT4A2 NM-C931 REV 1.0...
                                    09-06-2024, 01:33 AM
                                  • dclass-pro
                                    Problem with charge Lenovo LA-H131
                                    by dclass-pro
                                    Hi guys I have this Lenovo notebook that is driving me crazy:
                                    The customer says he goes into office but when the battery is downloaded all no longer, it has been for the day that we have in Test in the laboratory, I changed 2 new IC Charge batteries and the KBC (I reprogrammed it) and lplying it with a Banch power supply giving 20v to the laptop, start loading, then goes into stop, then after 5 sec. Start again, then stop and then start again and always load.
                                    I cotnrolled the 2 4K resistances on acin and are ok, what do you recommend?...
                                    01-23-2023, 03:54 AM
