Lenovo Y50-70 (LA-B11P) no charge problem
  • agswireless
    • Jul 2022
    • 15
    ok so I have this Lenovo y50-70 touch that has a no charge problem, maybe someone can point me in the right Direction since I cannot find a schematic for Borderview
    what are you guys opinion on where to start to check why its not charging?
    Back story:
    I bought this with a bad charging port, previous owner stated it charge fine but his kid kicked the cord and rip the plug and port out.
    so I ordered a new one, but when I was replacing the plug the open wire touch and made a spark because I completely forgot to unplug the battery.
    so I went a head changed out the plug and put it back together and it doesn't charge, no light or nothing i know that laptop works had a full charge before the battery drained.
    thing I done so far:
    replaced the port.
    replaced one of the mosfets because I had an extra one laying around, but no luck
    I tested the volt on the plug side of the board it gets 19V
    I measured the first mosfet PQ301 the drain and gate both sides measure 19v
    mosfet PQ302 gate measure 19v in and drain out 5v both the old mosfet and new one measure the same
  • mon2
    • 14720
    Post the topside markings of each mosfet.
    Remove all power. Meter in resistance mode. Measure the resistance across the mosfet.
    source & drain
    source & gate
    gate & drain
    Repeat for next mosfet.
    • agswireless
      • Jul 2022
      • 15
      resistance mode (200k) selected crappy multimeter
      I have to buy a better one
      1. mosfet 4447A
      S&D= 0 Continuity (beep)
      S&G= 0
      G&D= 0
      its short to ground I tested it in continuity, its the same results with the new and old mosfet
      2. mosfet S3604
      S&D= 103
      S&G= 0
      G&D= 107
      read high then numbers start to drop
      • mon2
        • 14720
        Remove both mosfets and then check the resistance across the pcb pads again. No power in resistance checks. Then check the resistance to ground for each mosfet; each pin group ( source / gate / drain). Flux the area well; remove with patience so pcb pads are not lifted.
        post clear pics of this portion of the logic board.
        • icanic
          Shorted drain to source on mosfet on Lenovo Legion 5 15ARH05. Please help.
          by icanic
          Greetings!
          I am trying to fix something and I have messed it up more.
          I have shorted mosfet (QX6 from the picture) drain to source on the laptop and laptop now only powering on and off.
          can someone help me identify what I burned? The mosfet is good.
          Full schematic of the laptop is in the link.
          Thank you!
          Full schematic in attachment.
          MOD Edit: Link to schematic -> https://www.badcaps.net/forum/showthread.php?t=112937
          Reminder: rules and organization of this section -> https://...
          07-20-2023, 06:45 AM
        • tofik
          MOSFET equivalent K8A60DA
          by tofik
          Hello guys,
          I have a shorted MOSFET K8A60DA with the following characteristics:
          Type Designator: TK8A60DA
          Marking Code: K8A60DA
          Type of Transistor: MOSFET
          Type of Control Channel: N -Channel
          Maximum Power Dissipation (Pd): 45 W
          Maximum Drain-Source Voltage |Vds|: 600 V
          Maximum Gate-Source Voltage |Vgs|: 30 V
          Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
          Maximum Drain Current |Id|: 7.5 A
          Maximum Junction Temperature (Tj): 150 °C
          Total Gate Charge (Qg): 20 nC
          Rise Time (tr): 25 nS
          Drain-Source
          07-19-2023, 05:18 AM
        • ebyte64
          Lenovo IdeaPad 330 laptop mosfet issue
          by ebyte64
          Good day everyone.
          I have been scratching my head with a Lenovo laptop I got in today.
          The laptop had no power and taking no amps from the power supply. Checking voltage showed 20v only on one side of the first mosfet. Took it off and replaced it and then same story. Took off second mosfet and then the first mosfet had the right voltages as well as 25v on gate is it should. Replacing the second mosfet the problem started again.
          Even using a wire to bypass the second mosfet does the same interference with the first mosfet.
          Would anyone...
          06-27-2023, 10:19 AM
        • Grafnus
          Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
          by Grafnus
          Hey there,
          first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
          So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
          Specs:
          • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
          • CPU, GPU, RAM work fine (not involved in the Problem)
          So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
          Now I noticed...
          08-06-2025, 11:54 AM
        • m0jo1103
          Need help.... Lenovo L340-15IRH mosfet missing!
          by m0jo1103
          Can someone please help me.. Mosfet is missing on this motherboard (Lenovo L340-15IRH) I cant find the part number.. Can someone please send me a picture or part number of the mosfet missing on the board.. Thankyou!
          05-19-2025, 07:13 AM
