Hello from France
My daughter spill some water on her laptop... Lenovo Ideapad Gaming 3 15ACH6, and she doesn't seen anything wrong after just remove the water with towel.
Then, later the laptop won't start anymore.
I've made a basic troubleshoot with my own laptop (same series)
So, the computer battery is totaly out. With my battery, the computer works !
But, with PSU connected, the latptop detect the power.. the harware led white is on, the amber one too and on the screen there is a 'batt charging' message.
But there is absolutly no charge to the battery. (And the laptop doesn't goes to auto off, and kill the battery)
So, I've found the wiring on this message (thanks Lisa Su) and here (thanks to AL._.EX )
I've made some basic checks, and then, found the following :
The +19V_VIN is OK (20.1 volts)
On the point 'A' (PD303 cathodes), with no PSU, the batt voltage is present, and with PSU, the 20 volts is present.
On the point 'B', there is always the batt voltage.
And then for all the following, same thing :
ACDRV-1 (PQ303/PQ310 gate), 0V with batt, and 2.8V with PSU connected
ACDRV-2 (PQ301/PQ309 gate), 0V with batt, and 2.8V with PSU connected
CMSRC-1 (between source and drain of the mosfets), 0V with batt, and 2.8V with PSU connected
I'm not able to do the check on the pads 3(CMSRC) or 4(ACDRV) of the BQ24800 (datasheet https://www.badcaps.net/download/?id=d1027792) and I can't locate the resistors.
But so, I think the BQ24800 is OK
Could you confirm PQ307 is a 'gate' between ACDRV and CMSRC command ?
Do you think that the problem root cause can be the mosfet PQ301/PQ303/PQ309/PQ310 ? Or can I check something else... ?
(probably 10 of each..)
